how to window switch with ltcc coil setup??
Old 08-28-2008, 03:01 PM
starbucks's Avatar
Default how to window switch with ltcc coil setup??
Does anybody here know how to hook up a window switch to a the ltcc coil setup, i tryed emailing bob but did not get a responce any help would be greatly apricated.
Old 08-28-2008, 03:22 PM
Nick@HSW's Avatar
What brand of window switch are you attempting to hook up?
Old 08-28-2008, 04:34 PM
starbucks's Avatar
well i havent picked a window switch to hook up yet because i dont know what will or wont work. I am looking for something i can lock out of first gear. i have read that harris speed works is coming out with a new window switch?
Old 08-29-2008, 07:23 AM
RyanA's Avatar
Should be able to use the tach wire right at the PCM. Its output is not affected by the LTCC.
Old 08-29-2008, 08:52 AM
Mike@HSW's Avatar
https://ls1tech.com/forums/nitrous-oxide/969326-new-microedge-nitrous-controller-hsw.html
Our new window switch will work with your setup. The tach wire would be a way to get a good signal
Old 08-29-2008, 01:05 PM
starbucks's Avatar
Originally Posted by Mike@HSW
https://ls1tech.com/forums/showthread.php?t=969326
thanks alot for the help mike i do have a question do i have to run everything that comes with the micro edge such as the tps activation or the duels stage control, all the difrent delays you offer. i basiclly want the window switch with a first gear lock out and the air/fuel lean shut down.
Old 08-29-2008, 01:30 PM
Robert56's Avatar
You could just use a WOT SW if you like, and my preference over the TPS. Any controller we can use which ever feature we want and by-pass the ones not needed and that's what is cool about the new controller with all the options, you may not need them now, but will be there for when changing the system around and trying other things, a great buy for the MicroEdge, IMO.
Robert
Old 08-29-2008, 03:48 PM
starbucks's Avatar
awesome thanks alot for the help. does anybody actually know where the tach wire is ?
Old 08-30-2008, 12:16 PM
RyanA's Avatar
A(RED) 13. It's the white wire...
