ATTN: MicroEDGE users...
im lost on 2 things.
the trigger setting for the microedge and interface, what do i set each one to?
also in the manuel for the micro edge it says
trigger 1 - tps/wot switch turn on for stage 1
trigger 2 - tps/wot switch turn off for stage 1
but in the walk threw it it says the trigger 1 and trigger 2 is to trigger the 1st and then 2nd stage.
how doees it know when you let off the gas?
I think you guys are looking at the TPS voltage triggers. What you do is go to the main screen with the battery on/car not running. Take the pedal to WOT and note the voltage on the screen. This is your trigger value.
Both should be the same value. WOT. Then you get into your timers to run the multiple stages. The MicroEdge knows you let out because the input to the TPS sensor.
they have it typed wrong then.
they have it as trigger 1 is turn on for stage 1
trigger 2 they have it as turn off for stage 1
should be trigger 1 turn on stage 1 trigger 2 turn on stage 2
i tired to do some testing but i could not get my n20 noid to click. i tried seting the rpm to 0 and also messed with the tps. never got the noid to click. im also using the interface i wonder if that wont let it spray.
but im not sure on 2 settings
Trig Mode on the microedge. do i set it to positive, negative or off
the trigger input seting on the interface (orange section) lt1-ls1 is on but what about the trigger +/- and the trigger pwr switch?
PM Sent
#35
went out and tried it.
i set the microedge to positive.
on the interface i turned the orange section to this
lt1-ls1 on up
trig power on up
and trig -/+ off down
set the rpm to 0. and lowered the tps so i wouldent have to rev it to much. reved it and the interface "spray" light came on. i could feel the n20 relay click. but couldent feel the n20 noid its self click
lt1-ls1 on up
trig power on up
