Wiring question (what 12v. power acc. do you use?)
Old 09-19-2008, 12:19 PM
LM97Z's Avatar
Default Wiring question (what 12v. power acc. do you use?)
Not the Battery 12v., but the Acc. 12v. on/off with switch, where do you run yours from? Do you go off the fuse panal or somewhere else? This will be for my Noids/Purge/Heater Acc. Heater & Noids will be run through relays.
Old 09-19-2008, 04:08 PM
jetlag's Avatar
Traction control.
Old 09-19-2008, 04:27 PM
bad6as's Avatar
fuse box for me.
Old 09-19-2008, 04:37 PM
krazy4's Avatar
The original owner before me had the amp going off a 12V source, so I just tapped into that line. Worked perfectly.
