New to NO2... Is this a full kit, and can I use this on a basically stock LS1?
It helps, Nitrous Outlet and Dynotune sell a great window switch that has options to lock out gears and is the wide open throttle switch. Harris Speed Works just came out with a new one with a lot of options called the MicroEdge.
Also, since you picked a dry kit, check out the Harris Speed Works Interface...you can spray the dry kit AFTER the MAF and it lets you adjust your air/fuel ratio easy!
For everything you need to have a safe kit, expect to spend $700-800
Honestly, that kit will get you spraying. There are a ton of accessories and safety devices out there. We need to know a little more about your setup to help you with accessory choice. With an A4 the WS is a little less necessary, but still an important safety device. It all depends the amount of risk you are willing to take with your engine.
Also, depending on the size of shot, you are going to need a way to pull some timing.
At a minimum I would run the following on an automatice car with a dry shot:
Window switch (up to you--protects motor in case of tranny failure and low end bog)
WOT (probably included in the kit)
Heater ( I played the torch game for a long time. It's a PITA and dangerous)
If you are wanting a dry set up. The single nozzle is a good basic route. However If I were going dry I would use our Halo system. It is proven to evenly discharge the spray mixture to where the mass air meter has no chance of not seeing the mixture. Most of the time the airfuel is pretty close to being dead on. In the event you did need aditional tuning to adjust airfuel you can do that with in PCM tunning.
Everyone has there own opion but this is the way I would do it if going dry..
We can put together a package for you with everything you would need for a safe and reliable set up.
Dave
Dave
