are TR6 plugs really recommended?
Old 09-30-2008, 10:35 AM
maggiemike's Avatar
Default are TR6 plugs really recommended?
what are you guys running for plugs with what kind of shot? I have TR6s gapped at .035 with my stock motor and shots ranging from 75-150 depending on the day, but i'm wonder if i'm running too cold a plug, and if I should run a larger gap.
Old 09-30-2008, 11:20 AM
Sigforty's Avatar
They are the right plug if you want to spray. Other wise for just running around NA with your mods I would use a TR55, but for spray you would have to swap to Tr6's when you wanted to use it.
Old 10-05-2008, 10:33 AM
black01_WS6's Avatar
the tr6's are good for a 125-150 and under. Anything over 150 I would get a step colder plug.
You are fine where you are at. Are you having problems?
Old 10-05-2008, 07:13 PM
maggiemike's Avatar
No, it seems to be working good right now, except sometimes I notice in 3rd gear that it almost sounds like the nitrous is kinda oscillating on and off. It's very hard to explain. I'm going to post up a video if I can
Old 10-06-2008, 12:27 AM
BIG NASTY's Avatar
The colder the better when you have a power adder that way you will be on the safe side. I use TR6's and they work fine and no on the larger gap .035 is fine maybe even .032-.030
Old 10-06-2008, 01:31 AM
krazy4's Avatar
Keep the TR6 plugs.
Old 10-06-2008, 02:33 AM
BobDoLe's Avatar
i'm using tr6's on a 125-150 dry shot with 21 degrees of timing. i'd consider tr7's but these seem to do fine.
