Kenwood DDX6019 Double Din DVD SYSTEM Excellent unit $275
Guys first off let me just say the Sound Quality and features this head unit has are amazing. I have had the unit in my car for about 3 years and was also used to provide video to a set of 7" TFT displays as well. I have the internal amp turned off and running my speakers off amps, but it is fully capable of running 4 speakers. Unit plays everything under the sun. Selling cheap because I have NO use for it. Went to a FULLY iphone 4 ready headunit. This unit physically looks perfect and includes the remote. Screen folds down to insert media behind the display. Sometimes when putting in a copied CD the disc will stick a bit and I just tap it and it continues. System has NEVER had the media get stuck. This might not happen to you but it has to me before and I want to be upfront. I dont switch media much. Usually have about 6-8 cd's on one anyways. HAHA This is a great unit for next to nothing. Here is a list of the specs and a canned picture. If you want to see it in action I can take live pictures just ask.
Specifications:
•Monitor Section
◦Picture Size : 6.95" (Diagonal) Wide
◦Display System : Transparent TH LCD Panel
◦Drive System : TFT Active Matrix System
◦Number of Pixels : 336,960 (480H x 234V x RGB)
◦Effective Pixels : 99.99%
◦Pixel Arrangement : RGB Striped Arrangement
◦Back Lighting : Cold Cathode Fluorescent Tube
•DVD Section
◦Disc Format : DVD-Video/Video-CD/CD-DA
◦Decoder : Linear PCM/Dolby Digital/DTS/MP3/WMA
◦Quantifying Bit Number : 16/20/24Bit
•FM Tuner Section
◦Frequency Range (200kHz) : 87.9~107.9MHz
•AM Tuner Section
◦Frequency Range (10kHz) : 530kHz~1700kHz
•Video Section
◦Color System of External Video Input : NTSC
◦External Video Input Level (RCA Jacks) : 1Vp-p/75-Ohms
◦External Audio Max Input Level (RAC Jacks) : 2V/25-Ohms
◦Analog RGB Input : 0.7Vp-p/75-Ohms
•Audio Section
◦Maximum Power (Front & Rear) : 50W x 4
◦Full Bandwidth Power (Front & Rear) @ Less than 1% THD : 22W x 4
◦Preout Level (V) : 2V/10k-Ohms
◦Preout Impedance : 600-Ohms
◦Tone Action : Bass:100Hz+/-10dB / Middle:1kHz+/-10dB / Treble:10kHz+/-10dB
Specifications:
•Monitor Section
•DVD Section
•FM Tuner Section
•AM Tuner Section
•Video Section
•Audio Section
