A/C Service machine - LS1TECH
Non-Automotive Classifieds Sell almost anything here, with the exception of firearms and ammo
A/C Service machine
Thread Tools Search this Thread
Old 04-13-2012, 04:13 PM   #1
toneloc60's Avatar
Default A/C Service machine
Used RTI RHS780 Digital Air Conditioning Refrigerant Handling System. This system retails for close to $5,000 new. It is used, and still very good. Everything functions properly. Has a bottle of R134A with about 8 pounds still in it. It's currently in San Antonio. Shipping weight is about 275. Buyer is responsible for shipping. I may be able to haul it for you depending on where and if the price is right. $2000 obo.
Here's the factory write up on it:
SPEED
* Patented Recovery/Recycling Process Heavy-duty compressor with true single-pass technology system for maximum throughput.
* Large Fan-Cooled Condenser
Speeds recovery, especially when temperatures are high and A/C service is in demand.
* 7 CFM Deep Vacuum Pump
Provides rapid evacuation.
* Integrated Oil Charge
Fast, easy method for oil charge.
* Digital Heated Power Charge
Programmable with high wattage thermostatically controlled heat belt. Refills most vehicles in less than 30 seconds.
ACCURACY
* Internal Weight Scale
Industrial-strength scale with shock absorber eliminates inaccuracies and frequent calibration issues.
* Rigidly Mounted Cylinder
Robust weight scale provides accurate measurement of refrigerant recovered from and charged to vehicle.
* Refrigerant Inventory
Accurate, continuous tracking of recovered, recharged, and available refrigerant. Long-term memory for cumulative refrigerant management.
AUTOMATION
* Fully Automatic Service
* Advanced Microprocessor allows you to program vacuum time, leak test, charge amount, etc... and walk away.
* Pressure Detection
Device automatically restarts compressor if residual refrigerant is detected.
* Single-Pass Auto Air Purge
Quickly and automatically eliminates noncondensable gases.
INTUITION
* Digital Readout
Easy to understand. Plain language information and technician prompts. No tutorial needed. So easy it makes any technician an A/C expert.
* Solenoid-Controlled
Gauge Manifold No panel valves to open and close. Solenoids automatically open high and/or low side, eliminating potential mistakes.
RELIABILITY
* Pressure Protection
Suction pressure regulator protects compressor and other critical components.
* Durable Components
Powder-coated steel cabinet and the highest quality compressor, solenoids, circuit board, switches, wiring, filters, weight scale...
* Field Proven Reliability
RTI A/C machines are the choice of the world's largest service chains and tens of thousands of satisfied customers around the world.
toneloc60 is offline   Reply With Quote
Old 04-16-2012, 12:47 PM   #2
toneloc60's Avatar
Price reduced to $1000. I would like this thing out of my garage. I need the room.
Old 05-04-2012, 10:17 AM   #3
toneloc60's Avatar
Sold.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
