Notices
Non-Automotive Classifieds Sell almost anything here, with the exception of firearms and ammo
KD Tools 2398 Automatic Transmission Clutch Spring Compressor (NIB - New in Box)
Old 08-22-2015, 12:07 AM
1950_Buick's Avatar
Default KD Tools 2398 Automatic Transmission Clutch Spring Compressor (NIB - New in Box)
$79.99 shipped!
I have several of these
AUTOMATIC TRANSMISSION CLUTCH SPRING COMPRESSOR
KD 2398 BRAND NEW!
Features and Benefits:
Permits easy removal and installation of snap rings
Tool compresses automatic-transmission clutch springs on some GM, Ford, Toyota and other transmissions
No need to remove center shaft and clutch assembly from the transmission housing
Simple and easy to use
This tool permits easy removal and installation of snap rings. It compresses automatic-transmission clutch springs on some GM, Ford, Toyota and other transmissions. The job can be completed without removing the center shaft and clutch assembly from the transmission housing. To use: force legs in and catch jaws inside transmission drum groove. Then, loosen wing nuts and adjust pushers. Lastly, tighten screw until lock ring is free to be removed. Its unique design makes it easy to use!
Attached Thumbnails KD Tools 2398 Automatic Transmission Clutch Spring Compressor (NIB - New in Box)-_57-55.jpg   KD Tools 2398 Automatic Transmission Clutch Spring Compressor (NIB - New in Box)-_57-56.jpg   KD Tools 2398 Automatic Transmission Clutch Spring Compressor (NIB - New in Box)-_57-57.jpg   KD Tools 2398 Automatic Transmission Clutch Spring Compressor (NIB - New in Box)-_57-58.jpg   KD Tools 2398 Automatic Transmission Clutch Spring Compressor (NIB - New in Box)-_57-59.jpg
KD Tools 2398 Automatic Transmission Clutch Spring Compressor (NIB - New in Box)-_57-60.jpg   KD Tools 2398 Automatic Transmission Clutch Spring Compressor (NIB - New in Box)-_57-54.jpg
Quick Reply: KD Tools 2398 Automatic Transmission Clutch Spring Compressor (NIB - New in Box)
