Rotary Revolution 4 post lift.
Rotary Revolution 4 post lift.?TRADES??
I have for sale a Rotary Revolution series 4 post 7000# lift. Lift is in excellent shape and was purchased December of 2005. Lift has very little use and has not been abused. Lift is red in color and has a few upgraded features including 6'4" height from bottom of rail to floor. Rails are the longest you can get in this model. I have zero problem getting my 05 crew cab on this lift with some length to spare. Approach ramps sit low to the ground so even the lowest car can get on without problems. I have had several F bodies on this lift and had no issues. Lift includes 2 jack trays that can slide front to back to place a jack under vehicle to do work which requires lifting tire from rails. I also have 2 drip trays that can be used for spills or changing oil. I will try to upload a few pics of unit. I will also incklude a website link to the manufacturer. Unit is located in the PRP area still set up in my garage. Minimum ceiling height I would have for this is 11'. My ceilings are 12'3". For anyone looking to buy I will help take apart and transport as well as reassemble. I still have all manuals that come with this new as well as receipts from when I bought it. This unit new is now $3750. I know that sounds expensive BUT trust me you get what you pay for in a lift. I did alot of research on lifts and Rotary makes one of the best. If you by a cheap $1500 lift you will end up with issues. I am needing to get $3000 out of this. From the right person I will even take payments BUT the unit will not leave my house until paid in full. http://www.revolutionlifts.com/four-post.asp Mine is the RFP7-XLT model. My motor unit is 220Volt. Located in Louisville KY 40216. Cell phone is 502-376-9408 Eric Jegray@insightbb.com
