Curious Tuning Idea for M6s
I ran across this on HP Tuners site this morning. Interesting idea....anyone got an opinion about if it would work? Might save your tranny or valve train at the track!
"Just got my hp tuner and I was gonna disable cags altogether when i decided it would be better to have it lock me out of 2nd when shifting from third to fourth at redline by changing the enable speed to 65 mph or so. Has anyone done this successfully? I was wondering since it also locks you out of third normally, when i change it is gonna lock me in third and not let me shift? Also, since the max disable throttle position is 100%, is this gonna disable it at wot anyway? I suppose when i let off the gas to shift it should enable it, but I guess it wouldn't work if i powershifted."
It would be a nice safety feature if it worked as intended... however, what Josh said is true. Besides, parts like a new short throw shifter help to alleviate that problem as well. Since I installed my Pro 5.0 a couple of years ago, I haven't made that kind of mis-shift.
I didn't know either, and I agree you SHOULD be able to shift. But I have heard more than 1 story about someone that power shifted into a lower gear & wiped out his valve train, so I thought MAYBE this would be a good safeguard.....if it's doable.
