Winter mod season has officially begun...
Thanks to Cory and Jimbo, the camaro mod fest started tonight. Got to work on the car about 4pm. Jacked and on stands by the time Jim and Cory showed. At at 10pm all is done.
Motor is on the stand, Tranny is on the ground and the Turbo is on the shelf.
Tore the heads off the engine. Everything inside actually looked VERY good. NO signs of detonation. At this point it just looks like the rings are too loose. Tomorrow I'll pull the motor down abit more and take a look at the ring lands and bearings.
Called Futral today, the engine ships out on Monday. Now I just get to play the waiting game for the heads and new converter.
Still deciding if a new intake manifold would be a good addition or not...
Looks tempting
Ryan
Looks tempting
Ryan
Originally Posted by Ryan K
My last car had a nice single plane intake (Old News), Had to cut a **** ton to get it to fit with a standard throttle body. Those pictures are someone else's, but I am "thinking" about it.
Do you think that intake will make a signigicant difference? the runners are so dirrect.........I would think it would help out a ton.....
Got yah..........you would need a cowl hood to go with that intake. Cowl hoods are so bad *** looking...
Originally Posted by jimbob
No problem...although I did forget the injectors
Ryan runs a cowl hood......He's already ahead of the game.....
that's right, he put that on just a couple of months ago.........I haven't see his car since then. He posted up pics while he was installing it.
Looks tempting
Ryan
Looks tempting
Ryan
Is the elbow that bolts to your intake the same size as a Holley base-plate? If so, I'd like to know where you got it and how much?
Originally Posted by esoteric
You are at the really enjoyable stage now. No stooping over the fenders at this point.
Ryan
