Northwest Members WA, OR, ID, MT, WY, SD, ND
My Symptoms
Old 02-24-2006, 09:16 PM
strobelite's Avatar
Default My Symptoms
What started everything: In cruise control around 90 car starts backfiring and losing power...almost like im running out of gas. take crusie control off put in nuetral car revs fine...After this these symtoms occur...
-Metal grinding noise in gear (Not out of gear)
-Noise stops after 2000 rpms
-Sounds like it is coming from the converter/flywheel area
Any ideas?
Anyone heard of this:?
It sounds like you may be hearing Pulse Width Modulation. What is happening is the lock clutch solenoid is sending very quick lock/unlock signals to the converter. The idea is to give a partial lock effect. It works well with the stock converter as its clutch is allowed to slip. Our more aggressive design doesn't allow ANY slip.
Old 02-24-2006, 11:39 PM
Robert56's Avatar
Not sure on your problem? How ya doing, haven't heard from ya in awhile. Miss us? or at lest the drag racing?
Robert
Old 02-25-2006, 02:09 AM
TwoFast4Lv's Avatar
You do NOT have PWM
Old 02-25-2006, 12:03 PM
strobelite's Avatar
Well that's good cause i have no idea what the hell pwm is lol
What I do have are metal shaving in the bottum of my trannsmission pan.
Old 02-25-2006, 12:07 PM
TwoFast4Lv's Avatar
IT sounds like your Converter is coming apart
Old 02-25-2006, 12:36 PM
strobelite's Avatar
Well thats better then the tranny coming apart! hehe. I had faith in yoru work. I have a 4000 stall on the way!
Old 02-25-2006, 11:39 PM
TwoFast4Lv's Avatar
Well....
The bad part is when the converter comes apart...It takes out the pump and transmission with it.
Ask Howierd....
Old 02-26-2006, 08:36 AM
strobelite's Avatar
Well at least it didn't come apart completely the car still ran fine with just that noise lol...And oh yeah the converter didnt lock-up...
Old 02-26-2006, 09:24 AM
TwoFast4Lv's Avatar
Drain the trans and strap it to a pallet and get it to me
Old 02-26-2006, 10:34 AM
strobelite's Avatar
How much that going to cost?
Old 02-26-2006, 11:10 AM
TwoFast4Lv's Avatar
Shipping will be biggest killer. I was only going to charge you for parts so what ever the damage to the parts is..
Old 02-26-2006, 11:27 AM
WAHUSKER's Avatar
The cost might seem high now, but if it did contaminate the tranny with 'spare parts' and you don't have Ellis go thru it, you'll be buying a new tranny very soon. And then your into the $3k range. You have to ask yourself if you can afford to take that risk....
Old 02-26-2006, 11:29 AM
CHarris's Avatar
... and the crap in the tranny will go right into the new convertor. It sucks but its the only way.
Rebuild with Ellis or Rebuild local. That is your only choice.
Old 02-26-2006, 11:31 AM
strobelite's Avatar
Would there be damage that wouldnt affect the overall performance of the car cuz the car ran fine other than the fact the noise..shifted great...Sorry just trying to analyze the situation
Old 02-26-2006, 01:17 PM
TwoFast4Lv's Avatar
Jake what happens every time you take a short cut? That converter was a short cut for a Yank or a PI and look where it got you
ALL of that stuff had to come back out some where and the pump is where. We just did Howierds for the Same problem and it took out the pump.
Maybe you have someone Local who can take care of it for you? Either way it needs done or you will get to buy another converter when you do the trans.
BTW DO NOT forget to flush the lines and cooler!
Old 02-26-2006, 01:24 PM
strobelite's Avatar
Alright, So hard is the pump to replace?
Old 02-26-2006, 10:03 PM
93TAWicked1's Avatar
Damn dude he just said he was going to do the labor for free. Crap I'd be all over that, parts are expensive but not that expensive.
I'd take him up on his offer....
Quick Reply: My Symptoms
