Any ideas??? please help
ok so after a hard night of muddin last night the jeep is acting funny. leaking fluid from the tranny, check engine light is on and while accelerating the jeep will start to surge really bad(like a hard jump). shift gears and it stops until you get into mid rpm's. any ideas?? Oh the jeep was under water last night and it died if that has anything to do with it.
Thanks,
Brad
Thanks,
Brad
The surging could be caused by a variety of factors. First, fix the transmission and ensure that there is an adequate amount of fluid in it. Second, see what codes are being thrown. It is quite possible that one or more sensors were damaged as a result of your water activities. Good luck!
ya i pulled all the interior out of the jeep since there was about a foot of water in it!! there appears not to be any water in the motor. i keep checking the oil. i'm going to goto shucks monday so i can find out what code i'm throwing.
