Northwest Members WA, OR, ID, MT, WY, SD, ND
Displacement increase, tuning timing
Old 08-03-2006, 12:11 AM
Poik's Avatar
Default Displacement increase, tuning timing
So I don't think many of you guys have actually increased your displacement without changing the heads around or anything like that, but I was wondering if there is some general rule of thumb in regards to the amount of timing a stroker engine will need compared to it's stock form. More or less is pretty much what I am looking for, thanks guys.
Old 08-03-2006, 01:06 AM
CHarris's Avatar
Timing may or may not change... but VE will.
Old 08-03-2006, 01:17 AM
Poik's Avatar
I found this a usefull link that some of you may enjoy reading:
http://www.daytona-twintec.com/tech_general.html
The table if you scroll down a little ways is a pretty good reference for things.
Old 08-03-2006, 07:33 AM
WAHUSKER's Avatar
For sure the VE will like Cory said. Timing will be more due to compression & rpm changes. I ran stock heads on a 402 with 40* of timing, but it had 11.5:1 comp & a BIG cam with a 750 dbl pumper Holley running pig rich with cold plugs. Red line was 7500.
