Northwest Members WA, OR, ID, MT, WY, SD, ND
Would ABS light cause a failed emissions?
Old 08-24-2006, 12:39 AM
93TAWicked1's Avatar
Default Would ABS light cause a failed emissions?
Seems like a stupid question, but emission tests can be very stupid. But if I put in a 9inch on a 3 channel car I'm going to get an ABS light, do they look for any lights or just a SES light?
Bobby
Old 08-24-2006, 12:01 PM
LSxChevelle's Avatar
Pretty sure it is only the SES.
Old 08-24-2006, 12:27 PM
Yeah I think so to, but just wanted to check if anyone else had one on when getting checked. I really would like to go with a 9inch instead of a 12 bolt but I loose abs, and the car hasn't been registered since it was new so I have to go through DEQ...
Old 08-24-2006, 12:28 PM
teh PuRpL3z
DrEvyl's Avatar
Not a SES... you get an "ABS INOP" light.
Old 08-24-2006, 12:31 PM
LOL I know that, I'm just worried some emissions idiot is going to be like "um you have light sir were not going to be able to pass you" I really don't THINK its an issue, but if it is I might as well order an 12 bolt or S60 because I don't have a good 3 channel 10 bolt, my 98's rear is a 4 channel...
Old 08-24-2006, 12:53 PM
teh PuRpL3z
DrEvyl's Avatar
I think the only things they can fail you for are things that wil generate a SES.
I have a 3 channel 10 bolt sitting around still... the carrier is busted in it, and it's a series 2 (2.73) rear end... but I do have one.
Old 08-24-2006, 01:02 PM
Thanks for that, but I have one too it just has a bunch of broken teeth on the ring and pinion I'm looking at about 2 weeks for a 9inch and then I loose my abs. We were going to fix the 10 bolt but the price was just too much for a rear that will be a time bomb....
Old 08-24-2006, 01:08 PM
teh PuRpL3z
DrEvyl's Avatar
So why a 9" instead of a 12-bolt?
Old 08-24-2006, 01:30 PM
Mikey 97Z M6's Avatar
1. Cheaper
2. Stronger
3. Modular
4. Can replace a set of gears on your bench instead of hunched under a car
5. Can have a spare center chunk ready to go
6. Easier to setup gears
7. Better selection of gear ratios
Old 08-25-2006, 08:28 AM
kickassT/A's Avatar
here anyway, you can't be failed for an abs light. you can however if the brake light is on. rule of thumb is if it's amber, you're ok, but red will fail you.
Old 08-25-2006, 12:03 PM
Originally Posted by Mikey 97Z M6
1. Cheaper
2. Stronger
3. Modular
Very true!!
Old 08-25-2006, 12:14 PM
1. Cheaper
2. Stronger
3. Modular
Yep thats about it, if I lived in TX I could see doing a 12 bolt but here in Portland its a big expense if anything go's wrong with it, plus the 12 bolt was about 500 more than the 9inch I picked up.
Moser housing
Strange center
Trutrac
1350 yoke
pinion support
Basically getting it in pieces but that is going to save me on shipping big time, together it has to go freight, in pieces they send it UPS. All that plus I can choose 3.89 gears for 500 less than a 12 bolt with a soft center section that distorts in high HP with traction.
The only problem is the 3 channel bracks so I may just ditch the ABS and go with a proportioning valve.
Old 08-25-2006, 12:19 PM
Rottluver's Avatar
Originally Posted by 93TAWicked1
Yep thats about it, if I lived in TX I could see doing a 12 bolt but here in Portland its a big expense if anything go's wrong with it, plus the 12 bolt was about 5k more than the 9inch I picked up.
Moser housing
Strange center
Trutrac
1350 yoke
pinion support
Basically getting it in pieces but that is going to save me on shipping big time, together it has to go freight, in pieces they send it UPS. All that plus I can choose 3.89 gears for 5k less than a 12 bolt with a soft center section that distorts in high HP with traction.
You keep saying "5k less"........as in 5 thousand dollars less? Or am I just missing something here? Never seen a $5,000+ rear end.
Not trying to be a smart ***, just looking for clarification.
Old 08-25-2006, 01:14 PM
LOL sorry you caught it before I fixed it, I've been spending so much damn money lately I guess I"m thinking of things in thousands instead of hundreds I fixed it though!
Old 08-25-2006, 04:35 PM
And where the hell is Portlan, OR? I keep looking for it on the map with no luck!
It's FRIDAY!!!!!!
Old 08-27-2006, 09:52 AM
Rottluver's Avatar
WHEW!!!!! You had me all scared and nervous.
Old 08-27-2006, 10:03 AM
Tech Addict
Rokko's Avatar
So what's it cost ya so far? I'm sure I'll be in the market for one sometime in the next year.
Old 08-27-2006, 12:21 PM
It was 2175 shipped. You can get the same setup with a Motorsport housing which really would have been fine, I'm a sucker for the upgrade though
With the ford motorsport housing your looking at only 2050 shipped!!!
I figure I'll have to pay to have the backing plates pressed on and get the bolt on spohn sway bar relocation and the driveshaft u joint setup.
But install shouldn't be that bad, install the housing first then put the center chunk in.
Quick Reply: Would ABS light cause a failed emissions?
