Northwest Members WA, OR, ID, MT, WY, SD, ND
LT1 Plate kits!
Old 02-28-2007, 10:01 AM
TwoFast4Lv's Avatar
Default LT1 Plate kits!
Tired of seeing Ls1 Tail lights? Well maybe it is time to step up to the plate....The NEW Nitro Daves LT1 plate!
For all you LT1 and L98 guys and gals out there our Friends at Nitro Daves are going to put a new LT1 Plate kit into production.
Nitro Dave makes the best LSx plates ont he market. They are now bringing that same quality and desighn to us LTx guys!
This plate fixes many of the issue old plates had. No interfance issues with linkage or distribution issues like Nossle and old plate designs.
Here is a look at the proto types kit
As you can see they went above and beyond to make this a nice kit
It can be had as a Conversion/update kit for only $250 or a full kit at $599. The kit comes with jets 50-200Hp.
So If you are tired of running just a hair behind step up to the Nitro Dave Plate kit!
Give me or the boys at Nitro Daves a call!
You KNOW Speed Secrets will be running one on a shop car!
Old 02-28-2007, 11:55 AM
Ryan'sSS's Avatar
Looks like you will be in the 9's soon enough.
Old 02-28-2007, 02:11 PM
Rockin C Racing's Avatar
So what is included in the conversion kit? Assuming the full kit is pictured. Will this work with other brands of kits? What are the Pro's and Con's of something like this versus a NX shark nossle?
Thanks
Old 02-28-2007, 03:20 PM
Chris@NitroDaves
Guest
Posts: n/a
Thanks
Here are the components that come in the Conversion.
The plate conversion will work with any other brand system. The biggest Pro is you will get better distribution with the plate. Another Pro is that it will clean up the install. The only Con that I can find is that when we first introduced the plate you had to do a little grinding on the Coolant filler neck because the plates were 3/4 in thick. The New versions will be thinner to eliminate that problem. The reason we discontinued the LT1 plate was because when they first were released there wasn't enough demand for the plates, but there has been a recent want for them so we are bringing them back.
-Chris
Old 02-28-2007, 06:01 PM
Thanks for the info.
Old 02-28-2007, 06:11 PM
Tranzor's Avatar
Hey, don't those types of plates work for an L98? Throttle bodies are pretty similar, aren't they?
Not that I'm planning anything, of course.
Old 02-28-2007, 09:42 PM
WAHUSKER's Avatar
Psssst, Ellis said LT1 AND L98 in his post.....
Old 02-28-2007, 09:49 PM
Tranzor's Avatar
You're right! Hmmm...
Old 03-01-2007, 06:59 AM
KrautBurner's Avatar
I hate your gutz !!!!
I thought I would have LT1's (except for ellis) taken care of.
