Northwest Members WA, OR, ID, MT, WY, SD, ND
Oil pressure problem?
Old 03-13-2007, 10:07 PM
Lunchbox01_chris's Avatar
Default Oil pressure problem?
So I was driving home a couple of days ago and sitting at my usual long *** light when my car began to shudder in pain, so instinctivly I looked at my guages first and saw that my oil was at the second mark below 40.( you know it starts at like 20 then there is a thick hash mark and then 40 and then another mark and then 80.. ) anyway it was jumping around violently from that second hash mark to 40. I worried and got it home and it went away when I got up the next morning. But then I noticed that the oil pressure is now at that 2nd to last big hash mark before 80!! Im worried. Anyone know what might be wrong? I believe normal is 40.
Old 03-14-2007, 11:07 PM
hmmm no ideas huh.
Old 03-14-2007, 11:15 PM
ssdriver27's Avatar
check oil level if thats good what kind of oil did you put in it ? how many miles on the motor ? oil pump possibly going, hope that points you in a direction to start. ~Guy
Old 03-15-2007, 07:03 AM
Oil level checks good. It has Mobile 1 synthetic oil. motor has 108000 miles on it.
Old 03-15-2007, 07:24 AM
WAHUSKER's Avatar
If the engine rpm's are jumping all over (like you seem to say they were) the oil pressure should do the same. Why it would suddenly be higher than it was is weird. Almost sounds like something partially plugged the sensor or a passage somewhere.
The issue with the LS1 pumps is they lose pressure - they go to 0 for no reason. But 01s didn't have that problem, or so I thought. My pressure when the engine is warm is around 50 driving, 40 idling, and >65 cold. On the stock motor it was about 10 psi less across the board.
Old 03-15-2007, 08:29 PM
engine rpms dumped to 500 they wernt jumping. The oil pressure needle was jumping
Old 03-15-2007, 08:51 PM
WAHUSKER's Avatar
I guess I need to read your sig.....98 eh? Replace the pump when you do the cam.
Old 03-15-2007, 09:05 PM
99blancoSS's Avatar
isn't it something similar to when you spin a bearing?
Old 03-15-2007, 10:06 PM
NVME's Avatar
Bad bearings would be shitty/no pressure at idle and decent pressure while cruising.
Old 03-17-2007, 12:48 AM
bearings?
the cams not getting done anymore. How much would a pump cost?
Old 03-17-2007, 09:45 AM
99blancoSS's Avatar
a pump is $150 or a less depends on what you get and where.
There is a spun bearing club in the internal section. Look it over and see if any of those symptoms match your problem. I know I was told oil pressure would be all over the place with a spun bearing and not just low pressure startup. It's is not uncommon for these cars.
Not challenging anyones knowledge either just throwing it out there
https://ls1tech.com/forums/showthrea...t=spun+bearing
Old 03-18-2007, 09:53 AM
WAHUSKER's Avatar
A spun bearing should give you low pressure at idle. Although if it just happened, you might see it fluctuate as the bearing goes away. I would be more suspect of the pump, or maybe the oil sending unit or the gauge. Might be worth tearing the dash apart & measuring what the gauge is seeing (voltage). THe sending unit is located on the top of the engine behind the intake manifold, where the old school SBC distributor is. It's a bitch to get to with the eng in the car! You have to remove the intake....
Old 03-18-2007, 11:59 AM
Racehead's Avatar
'01's did still have a problem, at least mine did. I had my pump replaced under warranty at 15,000 miles because of zero oil pressure on startup one time. I noticed instantly and flat bedded it to the dealer. Oil pressure jumping around seems more indicative of low oil level, spun bearing etc.
Old 03-18-2007, 05:16 PM
but I dont have a problem with it being low, its just really really high.
Old 03-18-2007, 09:45 PM
Ram4384's Avatar
chris I think that ur pump is still going out. Is it still the stock pump?
Old 03-18-2007, 09:57 PM
still stock, and 108,000 miles strong..
Old 03-19-2007, 10:36 AM
Rawr256's Avatar
I remember when the family Grand Am spun a bearing at 245k miles. I was driving it and it had no power, got louder and louder and oil pressure would fluctuate randomly. I checked the oil three times before I drove it to meet my dad because he thought the cat could have been plugged, I made it halfway to him before the engine totally seized. Different engine, but same situation.
I am not to familiar with the internals of the LSx engines, but when the bearings went on the Grand Am it just blocked flow to part of the engine, that is why it showed up full everytime I looked at it, it was full, just wasn't flowing.
Have any oil leaks? Filter on tight? Plug on tight? Those would cause oil pressure issues I would imagine. Mine runs consistantly 45ish at idle, probably close to 55 or 60 when cold.
