Northwest Members WA, OR, ID, MT, WY, SD, ND
cam
Old 05-01-2007, 10:10 PM
Lunchbox01_chris's Avatar
Default cam
Does anyone have the facilities and tools to put my cam in, or at least help me. I have no Idea what Im doing. I am also in arlington, and its my only form of transportation, so It will have to be done quick. I am off work on friday and saturday, so any help would be great.
chris
Old 05-01-2007, 11:17 PM
vtec this's Avatar
What tools do you have, and do you have a tuner?
Old 05-02-2007, 08:25 AM
I have a car, a hot cam, and 300 bucks.. my wife wont give me my ***** back for another few months.
Old 05-02-2007, 08:42 AM
KrautBurner's Avatar
you will probably need some valve springs and new pushrods too (that's over $300)
good luck
Old 05-02-2007, 09:25 AM
TwoFast4Lv's Avatar
good luck
Old 05-02-2007, 10:08 PM
aaah.. I have the valve springs too... what else? Why new pushrods?
Old 05-03-2007, 08:33 AM
so lets go over this. cam? check. valve springs? check. car? check sunny day soon? not likely.. what else, and why new pushrods?
Old 05-03-2007, 06:00 PM
vetred's Avatar
good luck
AND,......timing chain,.......hardend push rods,....80mm throttle body,..(BBK., $319 !) BIGINTAKEBIGMANNIFOLDBIGHEDDERSBIGHYFLOWCATSBIGAXC ELBACK,.........AAAAAAAAAAAAAAND A partiridge in a pear tree!!!!! (actualy im NOT kidding one bit),..(except for the partridge thing) (sorry)
Old 05-08-2007, 06:57 AM
Compstall's Avatar
+10 I'd do some research and figure out everything you need for a cam swap before getting started. The last thing you want is to find while you're knee deep in it that you need a part that is NOT in stock at any local parts store. Then you'll be down for days.
Old 05-09-2007, 01:07 PM
LSxChevelle's Avatar
I know he is selling the cam now due to selling the car but it's just a hotcam so why the 'need for pushrods. Yea if you go driving the car to it's limit all the time ok...but for a driver that gets on it once and a while I'd even consider leaving the stock springs.
Old 05-09-2007, 03:42 PM
SeaHawk's Avatar
I'm running basically stock and swapping out the pushrods now. I'll bring an example of why to the track Friday...
Old 05-09-2007, 05:38 PM
I wouldn't consider bent pushrods normal especially on a HotCam's lift though.
Old 05-09-2007, 05:51 PM
Tech Addict
Rokko's Avatar
Springs, pushrods and an oil pump are a no brainer if you're doing a cam swap. Timing set too if you're gonna have it apart for a cam swap. I don't think I'd want to test the stock springs on a hotcam or any aftermarket cam for that matter.
Old 05-10-2007, 03:22 AM
sidewayz28's Avatar
jason and i didnt do the oil pump or timing chain on mine
Old 05-10-2007, 08:40 AM
Thanks for the info, but the cam is for sale now, and my car is gone anyway. Thanks guys.
Specifications
SDPC Part Number: 12480033
Manufacturer: GM Performance Parts
Advertised Duration Int. : 279°
Advertised Duration Exh. : 287°
Camshaft Duration @ 0.050" I/E : 219°/228°
Camshaft Lift I/E : 0.525"/0.525"
Lobe Seperation Angle : 112°
RPM Range : 2200 - 6500
Camshaft Type : Hydraulic Roller
