Tech issues on stock Z28?
I don't *think* I'll have any tech issues with my '99 Z28 at the track, but I want to double check with the experts.
I remember battery hold-downs being a big issue before. Mine has the factory hold down. Will that work? Anything else I should be aware of?
Thanks
Thanks
Yeah, factory cross-brace is still there. Yes, its completely stock except for some of the programming stuff I did to it. ;-)
BTW Ryan, saw your car at TT last week. Its sweet! I asked why it was there. They said something about you and eights or something. I didn't ask too many questions. Lol.
Originally Posted by TwoFast4Lv
double check the battery hold down. they like to break in the front
speaking of tech at the track
do I need anything special to run ET streets on stock camaro (16x8) wheels. Seems like I read something about screw in valve stem. And since they're stock wheels, stock lug nuts/studs are fine correct?
Originally Posted by Ryan K
Drive shaft loop not required if the factory installed cross brace is still there. The one behind the transmission crossmember.
Hopefully its stock or you are gonna need a rollbar.
Ryan K.
Ryan K.
If it's a convertible you're probably going to need a roll bar..
Yikes. I don't know what stock LS1 Z28s run but seems like it could be close to 13.50.
"Honey, gotta put a roll cage in your car..." She'd love that. She already accuses me of fibbing when I say it's *her* car. I guess if I go with the cage, may as well add slicks, cam, 4.10 gears, torque converter, Ellis 4L60E and a 100 shot of nitrous. And maybe a better life insurance policy. Lol.
My stock 02 Z28 A4 ran in the 13.8's most of the time when stock with the 2:73's. The verts are heavier and I see most in the upper 13's stock. Doesn't take many mods to drop below 13.5. I never had a issue stock passing anything for the track, I did have a problem last time with my dark window tint, but they let me run.
I run nitto's on 16x8 wheels and nothing was required extra with the stock wheels, lugs etc.
