Looking for some mod recommendations..
Okay, so I have some more budget for mods, and I think my next step performance-wise is to start working on the induction setup, and if I'm gonna be changing the intake, I want to do a cam at the same time.. I also am gonna buy some new wheels / tires, and SFCs...
So I'm figuring that I'd end up buying a throttle body, cam, and intake combination. I figure if I'm gonna change the intake, I might as well change the cam while I've got it all apart. I also figured that I'd do pulleys at that time, also.
Anything else I should consider doing while I have it apart?
The car right now has a bone stock motor. Performance mods I have for it are Kooks LTs & catted y-pipe, GMMG catback, lid, 3.42 gears, and a Yank SS3200 converter. I also have a nitrous kit I'm going to put on and am planning on running a 100 shot.
My goal is to get the car into the 11-second range, but I don't really want to go faster than 11.50, because I don't want to put a cage in it. I would not have any opposition to leaving the nitrous kit off the car and building it to run 11's N/A if that would be possible.
Any recommendations on throttle body / cam / intake combinations?
I think you have a long ways to go before you'll get a lot of benefit out of an intake. They're expensive and don't get that much gain.
I know its not as glamorous as more power, but I'm sure you can find some more time by modifiying your suspension/traction/converter/gear ratio.
What kind of 60' times are you running?
What tires?
What tires?
Tech Addict
Get your TB ported.
Fast intake. Or, have Cory port an LS6 intake.
Cam to match your goals and rpm range. Have one custom ground by Cam Motion.
Of course an oil pump, timing set, etc....all that jazz that goes with a cam swap.
Maybe replace your rockers too??
I've got enough traction that I could add considerable power and still hook pretty good... and it's definitely time to be adding power.
Take a look, it's all aftermarket..
What tires?
What tires?
A large Cam I would think would net you what you are wanting to see out of the car. You have the auto so the rear end shouldn't me to much of a concern I would think.
What are you running currently? Just have bolt ons right? I am sure with a 100 shot you could get a low 12 or high 11 no problem.
If the option does ever become available, go with some sort of FI, TTi is right in your backyard anyway.
Shoot there is a LS6 intake for 350 locally, takes about 50 minutes if that to install easy HP.
I think you should by my wheels, Fikse's will make the car much faster looking
After that I would look at a cam setup over anything, I think that is the best bang for the buck and is an easy swap on the LS1 the intake doesn't even need to come off...
I'd look at a cam in the low 230's duration and high 500's on lift and 114. I always wished I would have picked up a F13 on a 114 when I was stock cubed...But I'm no expert I would recommend on going moderate. I've always wondered if that extra 10rwhp that you may get with the giant cams is worth the headache (obviously this is a generalization)
Bobby
Bobby
The LS6 intake already sold, too.. I missed out on it.
I agree, a 100rwhp shot will easily knock a second off your ET. This is exactly why I went the nitorus route, cause I can be a cheap bastard. I figured a 5 dollar jet could get much more hp than any bolt on, and thus my reason for not having headers. i think with your long tubes and a small shot you would have your goals at hand. But you probably are looking for more power n/a for bracket racing, and not going to spray while doing said bracket racing?
Robert
Robert
Robert
Robert
Tech Addict
Originally Posted by DrEvyl
That's pretty much it... I won't spray it unless I'm doing time only runs, and in the bracket I'll run it N/A... I'm pretty sure I can hit 11's on juice with what I have, but I'd like to get it down to at least low 12's N/A...
