Need some headlight help
My headlights dont work at all. All the other lights work fine. I have checked all the fuses and none are burned out. What could be causing this?
Dude, and you call yourself and electronics technician?
Your fired
Problem is it has a bowtie on it
J/K seriously, could be the switch or common wiring just to the headlights.
Good luck,
Ken
Your fired
Good luck,
Ken
It could be the switch. Is there anyway if the low/high beam switch was disconected, that it would that have the same syptoms. Reason being the switch hasnt been touched and I never used it any way. I usually just use the daytimes. Not to mention the steering colum was apart to replace the ignition switch a few weeks ago and I havent seen them work since then.
LOL Yes that could be the problem also
