Northwest Members WA, OR, ID, MT, WY, SD, ND
Cage install in Progress
Old 01-29-2008, 09:33 AM
Pathological Modifier
Ryan K's Avatar
Default Cage install in Progress
Well,
The cage install is progressing!
On friday night, I finally pulled the dash out of the car and started tearing into the heater box and air bag.
On Saturday, I got the floor plates welded in place. And started fitting the front down bars.
Then yesterday I got the main hoop, the rear down bars, the front down bars the front halo bar in and the Drivers door bar all in place. I'll try and get some pictures up this evening.
I have a question for some of you technical types. It has to do with how this sentence is worded.
Unless an O.E.M. frame rail is located below and outside of driver's legs (i.e. '55 Chevy, '65 Corvette, etc.) a rocker or sill bar, minimum 1 5/8-inch (41.2 mm) x .083 (2.1 mm) CM or .118 (3.0 mm) MS or 2-inch x 2-inch x .058-inch (50.8 x 50.8 x 1.5 mm) CM or MS rectangular, is mandatory in any car with a modified floor or rocker box within the roll cage uprights (excluding six square feet of transmission maintenance opening).
If you take out the () and Commas, it reads, Unless an OEM frame rail is located below and outside of the drivers legs a rocker or sill bar is mandatory in any car with a modified floor or rocker box within the roll cage uprights.
In my case my floor is unmodified and my rocker box is outside of my uprights... So am I legal without the sill bar?
Ryan K.
Old 01-29-2008, 11:03 AM
KTamez's Avatar
When in doubt call: (253) 826-8666 ask for Dave Schaffel
From the looks of it, assuming you're doing an 8.50 cert cage, you don't need them. A 7.50 cage will need them IIRC.
Old 01-29-2008, 12:16 PM
WAHUSKER's Avatar
They way I read it I agree with you Ryan, not needed. Although I think Ellis has them & might know the answer. I'm adding sill bars because my wreck showed that is the weak spot in the car.....
Old 01-29-2008, 12:29 PM
KrautBurner's Avatar
where's the pics
Old 01-29-2008, 01:01 PM
My1st Truck's Avatar
Man I keep meaning to stop and check out the shop and the car.
Been so busy with kid and redoing the upstairs bathroom.
I will get over there one of those days.
Old 01-29-2008, 01:51 PM
NWDragRacer's Avatar
Sorry, had to say it.
Old 01-29-2008, 02:20 PM
WAHUSKER's Avatar
And post some close-ups of how you ran the down tubes past the fuse panel / elec disconnect junction & pass-side air bag.
Old 01-29-2008, 03:15 PM
Ryan K's Avatar
Well, the passenger's side air bag is sitting on the shelf in the shop, most likely its final resting place. That is, untill I get a chance to blow it up. How many NHRA drag cars have air bags? Also, that is one heavy SOB.
Ryan K.
Old 01-29-2008, 03:40 PM
Ackattack1's Avatar
I don't think you need airbags when you have a cage and harness....just gets in the way. Plus the airbag might pop out when the chute releases.
Old 01-29-2008, 04:04 PM
Ryan K.
They sure are heavy and I know why.
I was just at a plant in eastern Washington where they make the explosives for the airbags - talk about a scary place. Most of the walls in the manufacturing area were 42" thick on three sides and just sheetmetal on the fourth side - just in case. Some building had a 40' berm surounding the building and many were refered to as 'magazines".
Old 01-29-2008, 04:11 PM
The Manalishi's Avatar
Isn't that stuff pretty inert without an electrical current or some kind of detonator? C4 is thats why I am wondering. sorry about the hijack.
Old 01-29-2008, 06:26 PM
turbo50's Avatar
Actually from the way that reads I think you are required to have sill bars because of the example they give is actually of a full frame car with a thick gauge exterior frame running along the rocker. Your car is a unibody and basically the only "frame" you would have right there OEM is a sheet metal stiffened rocker.
And btw my understanding is you are really not supposed to have an airbag when using a harness. Something to the effect of the airbag being designed for you to kind of lean into it at impact basically meeting it before its at full capacity softening the blow. The factory seat belt allows you to do this but if you can no longer lean towards it because the harness holds so firmly the airbag hits you at full velocity.
Old 01-29-2008, 07:18 PM
Ryan K's Avatar
Attached Thumbnails Cage install in Progress-roll-cage-2008-003.jpg   Cage install in Progress-roll-cage-2008-004.jpg   Cage install in Progress-roll-cage-2008-005.jpg   Cage install in Progress-roll-cage-2008-011.jpg   Cage install in Progress-roll-cage-2008-006.jpg
Old 01-29-2008, 08:41 PM
WAHUSKER's Avatar
Damn, I thought Ellis' car & mine were a mess.....
j/k, lookin good Ryan! I would like a better pic of the corners of the dash tho.
What seats are those?
Old 01-29-2008, 08:53 PM
Looks like a stock seat with pass through's cut in it and then stitched. Looks nice.
Old 01-29-2008, 09:29 PM
I will let Ryan chime in but when he first got the car I asked the same question about the seats and I thought he said the previous owner had had them covered like that. I could be mistaken though.
They looked very nice. That is why I remeber.
Old 01-29-2008, 10:04 PM
TwoFast4Lv's Avatar
Sill bars are coming. I chose to put them in now and not have to rip the car back ap rt later. I 'Think' the Driver side is required now. When it was Certified it was good to go.
After seeing how weak the rockers are I would not even question it. they buckle if you breath on them hard
The car sure feels good with all those bars in it
If you look at the way the front bars fit you will see why I did not like the way that set fit Heck that l that looks like my old Morrison kit
Old 01-29-2008, 11:43 PM
KTamez's Avatar
Well heres how to NOT do the front half. Courtesy of Ron Percy in Puyallup. This was subsequently used as practice material on how to use a saw to cut chromoly tubing OUT of a car........
Attached Thumbnails Cage install in Progress-driverdash.jpg   Cage install in Progress-frontpoint.jpg
Old 01-29-2008, 11:54 PM
I hope you are kidding. But if you are not HOLY **** what were they thinking?
Old 01-29-2008, 11:59 PM
KTamez's Avatar
Heres a few pictures of how a real Pro (Brad Hadman) did mine. Note this car had ZERO guts under the dash No Airbags, No wiring, No AC, No Heat. Who needs any of that crap???
Attached Thumbnails Cage install in Progress-12.jpg   Cage install in Progress-14.jpg   Cage install in Progress-10.jpg   Cage install in Progress-lt1.jpg
Quick Reply: Cage install in Progress
