Help! Adjusting aftermarket Hood
Hey guys i just installed my 4" VFN hood and its almost right. the right side is a little to much to the left. Also the hood doesnt go all the way down, how could i adjust it to make it right? heres a couple pics btw....thanks
I would loosen up everything and close the hood to see if you can move it into position the way you want it, so you need to find out why it wont latch.
If so, then you know its just a matter of getting everything tightend in the right spot.. I am not a paint/body expert but I know thats what I did when I put mine on, and it took several damn hours and some beer to finally get it looking decent.
I know it can be frustrating to install a hood - especially when it's your first time
But let me show these to our guy - he is excellent at troubleshooting these things...as he has installed them for customers in the past.
And I'm sure with some MINOR adjustments, this will sit correctly on the car for you.
I'll check with him in the morning.
It looks like you need to adjust your latch.
There are 2 bolts that you will need to loosen on your latch and move it over...this should allow the hood to sit correctly into place.
There is a diagram on how to do this on the instructional sheet we sent along with the hood as well.
Please let me know if you need any additional help~
Thanks!
Thanks!
There are 2 bolts on your latch that need to be loosened, from that point, you can adjust your latch and move it over.
When you are forcing a hood into a position it should not be in, there will be gaps because it is sitting over from where it should be.
This should take care of the problem...if not, then there may be some additional adjusting needed around the hinges.
But it usually does not come down to moving the bumpers or fenders in or around on our products.
You should have received an instructional sheet along with your hood. If not, let me know and I can send this over by fax or email to you.
It includes step by step what is needed to install the hood on the car.
Well **** i give up... this hood is not cooperating with me at all even when i test fitted it without bolting it on, there were spacing so im guessing the fitment is a little off but im gonna take it to a local body shop and see what they can do. Thanks for all your help
