Removing camaro License Plate holder
Old 06-12-2009, 02:28 PM
bad_408_vert's Avatar
Default Removing camaro License Plate holder
Does the bumper need to be taken off or just pull it off?
Thanks.
Old 06-12-2009, 11:23 PM
Dan Stewart's Avatar
I would remove the screws first..........just a suggestion....
Old 06-13-2009, 12:47 AM
? There are no screws holding the cheap plastic piece behind the license plate holder.
I want to install a billet grille if that helps?
Old 06-13-2009, 03:30 PM
Brangeta's Avatar
The year of the car would be helpful. If it's a '93-'97 you have to remove screws.
Old 06-13-2009, 07:51 PM
Sorry Its a 01.
Old 06-13-2009, 08:21 PM
Brangeta's Avatar
Most people just yank it off, but removing the entire bumper and separating it from the back side would be the method I'd do if I was going to do that.
Old 06-14-2009, 05:53 PM
cvalliere's Avatar
You can just yank like a mo fo but you're gonna have to take the bumper off if you want to put a differnt grille on.
Old 06-16-2009, 03:05 AM
Scira's Avatar
x2. You can do some damage if something catches while yanking it off
Old 06-16-2009, 11:33 PM
Vik
Vik's Avatar
I was concerned when I went to take mine off, but after reading that you just need to pop the two tabs on the far right and left out first, then the top has three tabs that are pinned in the back, just pull slowly with your back to some grass or something soft cause you are going to go flying back.
Old 06-17-2009, 02:39 AM
I tried yankin' it off this evening, the whole bumper was moving around like it was going to come off. I left it alone because I didn't want to deal with a ripped bumper. I 'll just take the harder way out and remove the bumper.
Thanks for input guys.
Old 06-24-2009, 02:28 PM
Pats Fan's Avatar
I've got a billet grille to put on too. I'm planning to take the bumper cover off to do it. It doesn't look to bad looking at the manual. Some plastic push fasteners in the top and a few nuts and bolts underneath and at the corners.
Quick Reply: Removing camaro License Plate holder
