mark removal? (pics included)
Old 07-24-2009, 07:12 PM
BlackMamba98's Avatar
Default mark removal? (pics included)
any suggestions on how to remove these marks?
and if you know what might have caused them would be greatly appreciated
side mirror
side mirror
front bumber
bumber close up
sorry for the quality :/ took with phone
thank you in advance
Old 07-25-2009, 05:16 PM
Duffster's Avatar
looks like bugs. . .
Old 07-25-2009, 05:24 PM
99'CajunFirehawk157's Avatar
Let me guess, the car is from the southeast part of the US? From those pics it look like someone left love bug splatter residue on the front of the car and they are baked on. Do they feel like they are on top of the paint or down below? If down below your screwed, repaint. If their on top a good detail shop may be able to save you. Good luck. Better pics would help.
Old 07-25-2009, 06:39 PM
billyb's Avatar
my guess is small rock chips then a fresh coat of wax and the dried wax residue is what is showing, i have the same on the front .
Old 07-25-2009, 06:53 PM
xxr98's Avatar
i have the same problem..its generally from dirt roads or rocks. but also it could be from bugs that have been on the car for a while. not sure how to make them go away other than repaint..then just keep it clean
Old 07-26-2009, 12:08 AM
DriftR's Avatar
I would start with clearcoat compound and if that doesn't work get more and more aggressive with white, then red compound and if need be, 2000 grit wetsanding paper until it is gone. Just be careful not to go through the clear!
Old 07-26-2009, 11:31 AM
billyb's Avatar
it's the clear that is chipped,
Old 07-26-2009, 11:09 PM
DriftR's Avatar
Well I don't know what happened to the OP, but If your clear is chipped use touch up paint to fill in the chips until they are at least level with the paint then sand them flat with 2000 grit wetsanding paper then compound, wax and your done!
Old 07-27-2009, 05:58 PM
riceeaterls1's Avatar
you can cover that by just having someone sand whole bumper with 600 then paint and clear
Old 07-29-2009, 10:51 AM
2002nbmssdd's Avatar
The only way to fix this is to paint it. Sorry but I am a painter and I have seen it a thousand times. Buffing probably won't do any good
Quick Reply: mark removal? (pics included)
