Removing Exterior Door Trim
Take a PLASTIC putty knife and carefully get behind one edge of the trim and pry it up. You should be able to pry or pull it off the rest of the way by hand. To get the double-sided tape off the car use a 3m rubber eraser wheel on a drill and it should come right off. Some parts houses carry them or u can go to a paint shop and find one. Its fool proof as long as u dont bear down super hard or have it turning too fast. Oh yeah make sure the panels u are pulling the trim off of haven't been painted on before. If they have and the trim was just taped off then u will have a mess once u remove the trim not to mention a big tape line. Hope this helps
