VHT trouble
VHT trouble
Ok, so all my side markers turned out fine but the lower section of my brake light cracked so I sanded it back down and resprayed but it cracked again!
What could be causing this? It is really humid today, would that be the culprit?
Any suggestions appreciated.
Didn't happen to me when I was paintin mine. They turned out great. Required very little sanding and buffing. Bad paint is normally evidence of bad prep work. Did you scuff them and wipe them down with something along the lines of isopropoyl alcohol (rubbing alcohol)?
Same here. Sprayed my tails and 3rd on my Camaro, the 3rd spider cracked like crazy and looked like crap. Sanded it, and sprayed it again with lighter strokes and a little more drying time between coats and it didn't spider crack again. Came out acceptable enough aside from the sanding marks showing through a little.
I may get an LED one later and VHT it.
I actually ran into an issue with my clear coming out dull on the side markers when I did it outside. Figured it was because of the humidity so I we sanded them down a bit, took em inside and hit them a few times on the stove with the stove fan on. They stayed glossy after that.
Still cracking with the 3rd brake light, may have to go back sand it down and hit it with VHT inside with no humidity.
I'm back in Philly now and not at my parents house where the car is so I'll have to post results when I do it.
