Help...looking @ a 01 sunset orange ss with peeling clear coat!
Old 09-14-2009, 01:19 PM
heymoej's Avatar
Default Help...looking @ a 01 sunset orange ss with peeling clear coat!
just like the title says.......
so far the clear coat is peeling on both doors & passenger rear quarter panel...
can just the clear coat be sanded off & then reclear the affected area, or does it all need to be taken off and repainted and then cleared?
and what to do, just do the panels that are affected now or redo the whole car?
i am afraid that more of the car is going to start peeling as time goes by.....
what are the options & whats do you think the cost would be to have a reputable car painting establishment fix this?
thanx john
Old 09-14-2009, 02:23 PM
CLRD4TO's Avatar
Im not a paint guy myself but the little experience I do have, it should be able to sand down and reclear. The hard part is telling if the damage is through the clear to the base.
Just a thought, but call a couple local body shops and tell them your story. Check with the seller to see if he can meet you at a shop. You should be able to find a shop that would give you advice, offer you will buy them a pizza for lunch instead of paying an hour of shop rate for a full blown estimate. That worked for me once at a tranny shop!
Old 09-14-2009, 03:11 PM
heymoej's Avatar
thats the problem,we are like 750 miles apart......
Old 09-14-2009, 08:28 PM
SparkyJJO's Avatar
A lot of shops give free estimates. Doesn't take long for them to look it over.
Old 09-14-2009, 08:50 PM
ws6pont's Avatar
Take it to a shop. If it is peeling, it needs to be repaired {removed and primed} and then repainted. The shop should be able to help determine how much of the car may have been painted in the past. You will want to have the color blended into the surrounding panels for the best finish. Price will depend on the shop. Could be a thousand, or three, just depends on the shop, the quality, and how much you elect to have done.
Old 09-14-2009, 09:24 PM
DriftR's Avatar
I do not believe you will get a good result sanding the clear down to the basecoat and then re-clearing the bad body panels. I would advise living with it or plan on a color blend and re-clear or entire re-paint if you are concerned with any of the other panels.
Not what you wanted to hear but...
Old 09-14-2009, 10:50 PM
A350SOM's Avatar
sunset orange metallic is also one of the most difficult colors to blend...even from the factory the color differed on the cars from the factory
BLULS1Z28's Avatar
if it was in my shop i would tell you to repaint the whole car after you do the repair and blendout you only left with a fender hood and bumpers maybe hatch so y paint all that and not whats left
Old 09-15-2009, 10:10 AM
SLICK_LS1's Avatar
IM HAVING THE SAME PROBLEM. But since half the car is getting reapainted i just did the whole car. Better in the long run IMO.
Old 09-15-2009, 01:49 PM
heymoej's Avatar
what price ranges are you talking,high & low??????
whole car paint......price?
blend price...........price?
Old 09-15-2009, 01:56 PM
z28mccrory's Avatar
Can you post photos of this peeling?
Quick Reply: Help...looking @ a 01 sunset orange ss with peeling clear coat!
