Bumper Repair
Bumper Repair
I have a couple questions about filling and fixing plastic bumpers. On the camaro i want to fill and smooth out the mounting locations for license plate etc... that are on the front bumper. What would be best to fill in the holes? I don't think bondo would be good on a flexible bumper.
Secondly i am going to put some RS ground effects on. However the ones on that mount to the front bumper have the mounting tab loop broken. Is there any epoxy out there i could form, sand/shape, and drill a new hole to fix the mounting tab? I was told mix-max bumper repair would work great for this? Any suggestions from the experts out there?
Autozone sells this two tube epoxy looking stuff called flexible plastic (or bumper?) repair for $6 or $7. Walmart has the same thing for $3
I've used it to repair rips in my front bumper cover, and it is strong and yet flexible. A minor fender bender a few months later didn't break it back open.
Yes, it definitely can be sanded and painted over. If you have the pieces, you can reattach them with it as well. I'd do a quick tack in a few places, holding it together with c clamps or something similar.
Then do a section at a time (you only have about 3-5 minutes to work with each batch you mix up).
I tend to use a dremel or sander to rough up the inside of the rip/tear/crack and fill it in.
Once hardened/dried I work on the outside (painted side).
Well the front ground affects I think this stuff will work on to rebuild the mounting tabs.
However in the rear there is actually a chunck missing that i need to use some sort of material or epoxy to rebuild it. it doesn't sound like this would be the ticket. I thought fiber glass would work perfect but researching it, sounds like it doesn't stick to plastic.... s
Also will this 3m stuff allow me to re-create sections that are missing? basically on the rear valence of the rs kit the bottom ledge has about a 3inch long by 1 inch wide section broken off. I would like to find something to essentially make a new piece and fill in that section that is broken off.
Ok let see plastic welding is ok but a pain.3m does make good stuff but I woyld recommend SEM brand the gun and tubes are cheaper and works the same. Quick 20 or problem plastic both work well there is also a quick 50 if you want a fast set but.not as fast as quick 20. I use is to fixed cracked bumpers, install body kits, and make new tabs..
