How to remove Krylon Fusion paint from plastic?
Old 12-29-2010, 11:37 PM
chon79's Avatar
Default How to remove Krylon Fusion paint from plastic?
So I hoped it would be warm enough to paint my cowl today. Removed from car, scrubbed em clean. Did nice even coats and all the paint did was run, turn milky, and make a mess What would be the best way to strip the paint and redo them?
Old 12-30-2010, 02:54 PM
lvbroham1's Avatar
try dot 3 brake fluid (old school hobby shop trick)
Old 01-01-2011, 11:34 PM
9WhiteCamaro9's Avatar
^ That or lightly wet sand. Like start off with a high grit sand paper so you won't take a chance on going to far down to mess up the piece thats painted and end up having to fill it where it went to far down.
Old 01-04-2011, 01:19 PM
chon79's Avatar
Thanks guys sounds like a bitch to do I was hoping there was an alcohol or liquid I could use.
Old 01-04-2011, 04:55 PM
BLULS1Z28's Avatar
plastic bumper stripper
Old 02-17-2011, 01:24 PM
chon79's Avatar
Hey guys, sorry to bump this thread, but if I go the wet sand method, what grit sandpaper would you recommend?
Old 02-24-2011, 12:08 AM
chon79's Avatar
Anyone?
Old 02-24-2011, 08:17 PM
Cheap Guy's Avatar
Oven cleaner might work, and I used a special paint remover on plastic model cars but absolutely DON'T use aircraft stripper. I will tell you that when I screwed up my grille when I tried to paint it with Fusion, it did not come off.
Old 02-24-2011, 08:22 PM
uphigh07's Avatar
i would just wet sand down the whole piece to not only remove paint but to make the plastic smooth so when you pait it, it doesnt look like sh*t
Old 02-26-2011, 09:37 AM
Opher's Avatar
Oven cleaner or straight reducer will take off most aerosol products.
Old 02-26-2011, 01:55 PM
70hemicuda's Avatar
brake cleaner works too lol
Old 02-26-2011, 02:08 PM
blackmambaSS04's Avatar
3-400 grit
Old 02-26-2011, 11:04 PM
Shutdown Theory's Avatar
^I agree
Old 02-27-2011, 12:01 PM
Cheap Guy's Avatar
It the trim plastic is anything like the grille plastic, I wouldn't recommend sanding it, especially with coarse sandpaper. All it will do is make deep scratches in the plastic (trust me - I learned from trying it).
The best bet is to use sandable primer if you can't remove the paint with chemicals.
Old 03-04-2011, 02:58 AM
bbs350z's Avatar
Will this work on krylon sprayed on top of platic chrome? I wanna strip thhe paint but retain the original plastic chrome
Old 03-06-2011, 08:06 PM
LilJayV10's Avatar
I am not 100% sure what you are working on but lacquer thinner and a green scotch brite bad should do the trick.
Old 03-15-2011, 10:11 PM
4doortypels's Avatar
hahahahahahahahahhahahahahaahhahhahahahhahahhaha i did aircraft stripper.... IT WORKS GREAT> again WORKS GREAT... it bubbled up alllllllll the down to the metal... took everything...
Old 03-16-2011, 07:28 PM
InsaneAuto86's Avatar
reading comprehension > you.... again, the thread is about removing paint from PLASTIC
Old 03-17-2011, 12:44 AM
LilJayV10's Avatar
Glad I'm not the only one who thought that.
Old 03-17-2011, 12:59 AM
ANTICOP RAM AIR's Avatar
can you take them to the local car wash and hit it with a power washer... you would be suprised how much that **** will come off... after that, try lacquer thinner or reducer. I wouldnt used break fluid... the plastic is porous and you will probably not get anything to stick to it ever again.
Quick Reply: How to remove Krylon Fusion paint from plastic?
