How hard is replacing PS door?
Old 01-06-2011, 09:44 PM
SnIpEz's Avatar
Default How hard is replacing PS door?
My door was backed into by a Silverado (don't ask about the insurance, long story) so basically I'm stuck to fix this myself. Too cheap to pony up the cash to have the shop fix the door, the fiberglass is splitting and whatnot.
I found a perfect condition red door locally at a salvage yard and I was wondering how hard it would be for me to take off my old door and attach the new one? How likely would it be to sag? I'm sure the wiring is difficult, but that aside, how hard/long would you say the process is for a person whose never done it before? Btw I'll likely be replacing the fender in front of it as well so that won't get in my way too bad if need be
Old 01-07-2011, 01:47 PM
SnIpEz's Avatar
Someones had to have done this before?
Old 01-08-2011, 02:43 AM
Trev_SS's Avatar
I don't think that it could be that bad just time consuming.
What salvage yard did you find a good looking door at in dfw? J/C
Old 01-08-2011, 02:59 AM
SnIpEz's Avatar
Its actually right outside San Antonio D: I dont know WHY I said locally. My bad. new to this area and need to look around
Old 01-08-2011, 04:01 PM
toplessHO's Avatar
remove the fender first.then remove the 5 (or 4, depending on year) bolts.
disconnect all the wiring inside the door first and fish wiring out.
assemble in reverse order.
Old 01-08-2011, 05:38 PM
SnIpEz's Avatar
Thank you! So it's a fairly straightforward thing I'm guessing? Id just hate to do this and not be able to get the new door on or have it sag and not close. Everything *Should* line up and fit perfectly? Ill probably be replacing the fender and bumper as well. The car is my only ride right now and I'd like to be able to finish this in a day, two MAX. Think that's reasonable?
Old 01-08-2011, 06:26 PM
toplessHO's Avatar
should be fine in one day if youre all thumbs
take lots of pics of fasteners and mark the baggies
where they came out of.
Most likely will break some plastic push pin retainers
so have a few new ones on hand.
Old 01-08-2011, 09:33 PM
Super-Bat's Avatar
I'd be willing to lend a hand if we can coordinate a time/place to knock it out.
Old 01-10-2011, 11:58 PM
SnIpEz's Avatar
Well since its local to you, I would not mind that at all. Once I finish getting settled in Texas expect a text from me sir
