Fender Liner Replacement
Old 01-26-2011, 08:27 PM
HotWS6's Avatar
Question Fender Liner Replacement
I have a 2000 Trans Am WS6, what are the steps to replace the front fender liners and is there an instruction manual anywhere? Anyone done this before, and where did you order the parts?
Help is appreciated!
Thanks!
Old 01-26-2011, 10:34 PM
LS1Tech Administrator
RPM WS6's Avatar
Received 1,486 Likes on 1,069 Posts
I did this several years ago on my '02 car. There were 3 push-pins to remove (I was not able to reuse them) and 2 or 3 screws I think. The job is pretty straight forward. I bought the replacement push-pins and new liners at a local GM dealer.
One thing I do remember was that the new liners did not have holes pre-drilled for the screws. I think I just laid the new liner over the old one (once removed), and pushed the screws through from the back side to make a mark were the holes needed to be drilled.
Old 01-28-2011, 05:51 PM
HotWS6's Avatar
Thanks! Did you have any installation instructions and did you have to remove the fender?
Old 01-28-2011, 07:38 PM
RPM WS6's Avatar
There is no need to remove the fender at all, but you will need to remove the wheels.
There are no real instructions for this job. It's very straight forward. Just be careful not to damage the paint on the fender lip when you're pulling out the push-pins.
Quick Reply: Fender Liner Replacement
