Fender alignment?
Old 02-08-2011, 09:19 PM
98ragz28's Avatar
Smile Fender alignment?
I did a couple searches and read through all of the stickeys but had no luck. I have noticed that on my car (and a few other fourth gen F-bodys) that there is a "gap" between the body and fender towards the bottom where it meets the door. Is there any adjustment that im not seeing or is there abbigger problem? Any help is greatly appreciated.
(not my car but this is what im talking about)
Old 02-08-2011, 09:43 PM
technicalninja's Avatar
The flange on the bottom of the car where the fender bolts on may be bent outwards. It's flimsy and takes hits from debris. I'd check that out first.
Old 02-09-2011, 06:31 AM
keith102371's Avatar
also alot of people think that flange is a jacking point, ITS NOT!!! and will bend it, if its bent, there are 2 10mm bolts there, un bolt them and staighten the flange, and its best to heat the fender with a heat gun, (sometimes if the fender flange has been bent for a while, the fender will crack when u try to bolt it back up to the straighted flange and heating the fender will help with this) get good and warm but not too hot, if u dont have a heat gun, use a hairdryer, u may have to play with the location of the flange to get the gap right, I worked in the body shop of a Chevy dealer for 18yrs and seen this ALOT, If you have any more questions just ask.
Old 02-09-2011, 03:30 PM
98ragz28's Avatar
ok ill take a look. thanks
Old 03-20-2011, 11:26 PM
01 CamaroSS SLP's Avatar
How did it turn out? i just fixed mine and it looks a whole lot better.
Old 03-20-2011, 11:31 PM
98ragz28's Avatar
Turned out the brackets were bent as others suggested. Pics of the car with pain are in my other thread "fresh paint on my 98 z28 vert"
Old 03-21-2011, 02:18 AM
Marc3.4V6's Avatar
I can't see what you're talking about, can you be more descriptive in that picture you posted??
Old 03-21-2011, 05:43 AM
98ragz28's Avatar
Well my problems already been solved but its the gap in the middle of the circle. I don't know how else to explain it.
Old 03-21-2011, 06:24 AM
Captain Double Post
BOBS99SS's Avatar
Mine has the same thing,I'm off work today so (its lil project time lol)
Old 03-21-2011, 07:11 AM
Captain Double Post
BOBS99SS's Avatar
Just checked mine out,its bent all to crap,
Old 03-21-2011, 11:10 AM
Before
After
Driving up on that piece of wood made the clearance a lot more easy, your pliers might not make it if you don't.
Old 03-22-2011, 12:17 AM
The Mighty Texan's Avatar
Gotta fix mine too thanks to the 1st owner..
Old 03-22-2011, 02:27 AM
SSCAMARO02LS1's Avatar
excellent call keith. Whenever you take your car to a shop for any repairs where the car has to be lifted, be sure to advise the Shop about this issue. Make sure they don't put the jack / lift on this flange ( some shops are more careful than others. ) If this flange gets bent too bad and you or the shop tries to correct it without doing it right... it will certainly crack causing a major issue with the bolt holes. Unless you are really handy with fiberglass, it could possibly require a new fender depending on how picky you are with the way your ride looks.
Good info,Thanks.
Old 03-22-2011, 06:19 AM
98ragz28's Avatar
That's why I prefer to do all work myself with the help of father
Old 05-16-2011, 12:55 AM
68Goatboy's Avatar
mine on one side is bent so far up that there is no way the bolts are comming out. should i still try bending or banging it back into place?
Quick Reply: Fender alignment?
