Does Any 1 know How to..?
Old 06-08-2011, 06:05 PM
09camarossls2's Avatar
Default Does Any 1 know How to..?
Exterior Door Window Sill (guide) (Plastic)...??
Does AnyBody Know How To Remove & INSTALL This Back..? I've had Bad experience on my Last Camaro tryN to remove it.. And Wasent able to leave it back how it fitted B 4 i messed with it.. It seems once You remove it.. it wont fit Nice And Tight again.. Pops-Out.. THANX..!
Old 06-13-2011, 10:14 AM
Fireball's Avatar
it snaps in. I had mine off and back on no issue...took me a few hours of messing with it to get it figured out though...
Old 06-13-2011, 10:17 PM
mrrman's Avatar
the one in my 87 TA slides in and then it is secured by screws( from the inside)
Old 06-17-2011, 03:44 PM
Swiat34's Avatar
I've heard the 4th Gen ones are held in with double sided tape. People use butter knives or the smaller metal scrapers.
Old 06-17-2011, 04:37 PM
VinR1's Avatar
its held on with clips that squeeze the fiberglass and have little barbs on the inside
the best way to remove is roll the window down, start at the rear of the door and, using both hands, roll it towards the interior of the car. Just roll a few inches at a time and you'll see how the rest of it will come off
to put back on, use some pliers to squeeze the little clips tighter - start closest to the mirror and just push down
Old 06-18-2011, 02:30 AM
what..?? Really..?? That would be a good idea though..
I actually Seen "clips" on my last 4th gen.. but cant really put it back the way it originally Fit. Am gonna go ahead and try My best.. What ever time it takes to get her right..
but worst case scenario:
Old 06-18-2011, 06:28 AM
Odessa620's Avatar
I had mine pop out for the last year on my firebird, I would get it in thought it was done right, then a week later I'd go to roll my window up and it would pop out, was a huge pain in the ***, if you shut the door too hard it would pop back out. Subscribing in hopes of useful future tips other than the ones already stated, because they didn't work too well.
Old 06-18-2011, 08:57 AM
Grr
Grr's Avatar
its best to remove the mirrors as well or you will be more likely to scratch the paint. Remove the mirror, door panel, and it would give you more room. Pull almost straight up on the window trim and it should pop out
Old 06-20-2011, 02:03 PM
+2
Thanx Am going to give everything a try.. LoL..
Any More Helpfull tips or advice..? Thanx Evrybody..
