How To: Fix Your Fender Gap *Pics*
Old 07-24-2013, 03:55 PM
  #41
FormulaJoe's Avatar
I just did this the other day. No pics, but it worked great. That alignment problem bugged the crap out of me.
Thanks OP!
Old 07-27-2013, 10:35 PM
  #42
dkkc's Avatar
take fender loose an then straighten flange...those fenders crack easy..
Old 10-11-2013, 05:35 PM
  #43
Zaz33's Avatar
Nice I was wondering how to fix this mine has this on the drivers side.
Old 10-13-2013, 07:48 AM
  #44
Mista Blazer's Avatar
Wouldn't adding a little heat to both sides help avoid breaking the tab off? Just a thought feel free to kick me down for that haha
Old 10-25-2013, 10:07 PM
  #45
utlonghorns13ser's Avatar
fixed my fenders tonight. driver side required a little extra work but nothing too difficult. passenger side took 2 minutes max. this thread was a lot of help
Attached Thumbnails How To: Fix Your Fender Gap *Pics*-10-25-13-044.jpg   How To: Fix Your Fender Gap *Pics*-10-25-13-048.jpg
Old 10-25-2013, 10:13 PM
  #46
Daniel Richards's Avatar
I did mine when I had it up on ramps for the oil change last weekend, got the driverside pretty good, but the passenger side had been folded clear back and caused it to break the the lower fender, I straightened it but it doesn't matter since it's broke off clean.
Old 11-28-2013, 08:00 AM
  #47
02NavySS's Avatar
Just wanted to thank you for posting this thread, I just fixed mine and will be passing the info onto a friend!
Old 11-28-2013, 08:53 AM
  #48
JOHNNY59's Avatar
I have seen them so damaged that the fender mounting tab is broken off and folded under the metal mounting flange! I'll remove the fender and use Plastic Welder epoxy(best epoxy I have ever used!). if the mounting tab is bent I use a heat gun and form the tab back into shape. I do my own work on all 5 of my f-body's(yes 5). the only time my car is on a lift is at inspection time and I have to tell the mechanic where to jack, some don't take it very well!
Old 11-30-2013, 07:17 PM
  #49
bart27's Avatar
I have a 2000 ta my drivers door is hitting the fender on the middle of the doore when I close it has anyonedumhad this problem?
Old 01-15-2014, 03:58 PM
  #50
Striker's Avatar
Bringing her up from the dead fellas.
This is a good question- can someone elaborate? I really don't want my tabs to be broken either.
Old 01-15-2014, 04:10 PM
  #51
jsteele90's Avatar
as long as you disconnect the fender from the tab there is no risk of breaking the tab.
Old 01-16-2014, 08:36 AM
  #52
Striker's Avatar
I will try- the tabs are bent to **** almost touching the floor boards. To my surprise, they aren't cracked from the looks of it?
Old 01-16-2014, 09:06 AM
  #53
calgary_z28's Avatar
Good stuff..I fixed my passenger side with a block
of wood and a rubber mallet. 2 minutes later and
she's as good as new!
Old 01-21-2014, 01:40 AM
  #54
dhctss's Avatar
I unscrewed mine then i bent bracket and rescrewed. The wood didnt work but mine were really bad like some others. One is perfect and the other neefs a litle more adjusting. Night and day though
Old 01-21-2014, 04:30 AM
  #55
MasterTomos's Avatar
This isn't an issue on LT1 cars at all, due to the jack point mounts on them. I've fixed several on my buddy's 98-02 cars that have had this issue and, for whatever reason, GM didn't put them on the 98-02 cars. LS1 guys may want to look into a set on these from a junkyard to prevent this issue from happening again after you fix it. (2 bolts)
Here's some on ebay
http://www.ebay.com/itm/93-97-LT1-camaro-firebird-jack-pads-trans-am-WS6-SS-/191016983739?pt=Motors_Car_Truck_Parts_Accessories&hash=item2c797fdcbb&vxp=mtr
Old 01-21-2014, 05:02 AM
  #56
AronZ28's Avatar
I had to fix this issue on my old 1999 Z28. Every time I took it to the shop, I put florecent masking tape all over that part you aren't supposed to jack, along with a big arrow pointing down and a huge NO in masking tape right above it.
Old 01-21-2014, 08:31 AM
  #57
FormulaJoe's Avatar
Definitely a problem on lt1s... Mine were so terrible on my car, one side is so mangled I'm pretty sure I'll have to weld on a new mounting point for the fender... Buddy with a 97 TA has same prob... All depends on how stupid previous owners of said car were...
Every book that comes with a lift that I've read specifically shows to put the lift pucks under the subframe (right where the front and back of SFCs connect) for 93-02 fbodys. I would never trust that shitty plastic thing to jack my car up on, not to mention I'm pretty certain it even says right next to or on the plastic block to NOT jack in that spot. I'm guessing they removed them simply because they were pointless..
Old 01-21-2014, 05:11 PM
  #58
Striker's Avatar
Here's some on ebay
93 97 LT1 Camaro Firebird Jack Pads Trans Am WS6 SS | eBay
Someone that has these jacking pads correct me if I am wrong: I heard that they are pretty useless and would crack as soon as you jack the car up? True, or BS?
Old 01-21-2014, 05:17 PM
  #59
Striker's Avatar
My thoughts as well- the spot you are referring to for proper jacking is the 'frame rail' that behind the front wheel, that goes to the floor boards right?
Old 01-21-2014, 08:27 PM
  #60
FormulaJoe's Avatar
Exactly, the frame rail was the term I was looking for...
Quick Reply: How To: Fix Your Fender Gap *Pics*
