removing tailight tint - LS1TECH
Thread Tools Search this Thread
Old 04-12-2012, 05:24 PM   #1
k_garretson23's Avatar
Default removing tailight tint
Friend of mine took her 04 jetta to some guy to have her tailights tinted. Despite what i told her she went through with it and naturally the guy did a **** poor job. Looks awful and its way too dark. Is there anyway to get this **** off without damaging the lense? I dont want someone to slam into the back of her and say its her fault because you cant make out the tailights. I mean in the day time you can barely see them at all. Idk what the guy used im assuming vht.
k_garretson23 is offline   Reply With Quote
Old 04-12-2012, 05:40 PM   #2
98camarols1's Avatar
you can use heat gun.start heating it and start pulling it.the glue what sucks.after removing all the tint,clean the light with like prep solvent to get rid most of the glue.then wet sand it with 1500 and then buff it out.i removed it for friend of mine on 350z.the glue messed up the clear-coat.so i had to re-clear his light.after you buff it and you still see little cracks everywhere means the clear is cracked.
98camarols1 is offline   Reply With Quote
Old 04-12-2012, 11:20 PM   #3
02CamZ28's Avatar
you can also use gasoline thats what i did to mine
02CamZ28 is offline   Reply With Quote
Old 04-12-2012, 11:36 PM   #4
you said vht.. assuming its the spray tint? i used laquer thinner, worked fine
critical.in.ga is offline   Reply With Quote
Old 04-13-2012, 02:39 PM   #5
Striker289's Avatar
if its Niteshades, I would sand it off then buff the lights. I sanded mine down to retint them a while back.
Striker289 is offline   Reply With Quote
Old 04-13-2012, 04:44 PM   #6
Quote:
Why scratch ur lenses up when you can just wipe it off with some gas/laquer/paint thinner/etc... ?
Old 04-16-2012, 09:52 PM   #7
junior98's Avatar
Quote:
If you do it with a fine enough sand paper and then clear coat them it will make it like scratches are not even there.
Of course this all depends on whether or not they were sanded to begin with, if not there is no reason that the paint thinner shouldn't work, if so they're going to look pretty bad when the tint comes off. lol
junior98 is offline   Reply With Quote
Old 04-16-2012, 10:14 PM   #8
Yea I guess if whoever did them, did them right.. they should have scuffed up the plastic before spraying the vht.
Old 04-17-2012, 06:09 AM   #9
bones_c's Avatar
what i did to my vht (because it was scuffed prior) was sanded it down with a palm sander and 800 grit, once it was all removed i took to hand sanding my way up to 2000 grit and let them dry, applyed wax and grease remover and about two coats of clear coat. i had to sand mine off to pass inspection so it was temporary. once i had inspection done i resprayed with vht again soo... using the palm sander and then hand sanding my ta tails and marker lights only took a total of about 2 hours to sand, wetsand, then dry, and shoot with clear. not hard to do
bones_c is offline   Reply With Quote
Old 04-17-2012, 08:47 AM   #10
Quote:
thats why i keep a spare set of lenses
quickkris2006 is offline   Reply With Quote
Old 04-17-2012, 10:50 PM   #11
bones_c's Avatar
yea a set of spare lights would be nice... but not worth it to pay 500 for a set of ta lights just to sit around for a once a year inspection... have a few beers and clean up the lights... no problem for me... that just means i get a few more beers when i redo the tint lol
Old 04-18-2012, 12:13 AM   #12
AmarilloWS6's Avatar
I poured acetone on my lights and the VHT just ran off, really didn't even have to wipe it lol
AmarilloWS6 is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
Berger Panel Pics Midnight00SS Appearance & Detailing 40 11-25-2010 01:55 PM
Got my tailights tinted Zach79Z Appearance & Detailing 18 04-17-2009 12:44 PM
I think I might try this newton Appearance & Detailing 11 04-17-2008 03:20 PM
Whistler Mod-Tailight-fix??? Transam 99DWPTA Appearance & Detailing 1 03-07-2008 08:39 AM
Thinking of blacking out my tailights... [Pics] Gev Appearance & Detailing 12 12-29-2002 11:26 PM
Tags
410, 91, camaro, gears, removing, s10, tint
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
