Location of Lt1 mounting brackets
So I'm swapping out the Ls1 nose for an Lt1 nose on my 2002 SS camaro. Can anyone assist me on where these mounting brackets are. any photos would be a huge help.
I know this mounts to the fender but how/where does it mount to the chassis itself
these two I dont have a clue on location there is obvious a right and left but where/what do they attach to?
The bottoms two brackets hold the headlight panel to the core support. They bolt to the radiator/ core support by the washer fluid tank. The top bracket holds the fender and the bumper together. The two studs to down through the holes in the fender and nuts to on those to hold the bumper/ fender gap together. The other side obviously bolts only one way to the car itself. Once you put those studs through the fender you should be able to mate it up correctly.
