2000 ws6 headlight problem.
Old 12-16-2014, 05:12 PM
Huffdaddy's Avatar
Default 2000 ws6 headlight problem.
I'm having a problem with my passenger side headlight not wanting to pop up. I put a new motor in and the headlights come on but only the drivers side pops up. Could it be the harness to the new motor?? Or does anyone know if they have separate fuses for each headlight??
Old 12-21-2014, 11:37 PM
BBWS6's Avatar
I had the same problem. Driver side would pop up but not passenger. When I would lock/unlock the car the drivers side would pop up and down. There is a fuse for each side. Check the fuses first under the hood. If you replaced the motor then it's the headlight control module (it's what I replaced and it fixed all
My problems). Hope this helps.
Quick Reply: 2000 ws6 headlight problem.
