I want to swap door skin ?
I want to put a manual window door on my car and take off the electric one that's on my car. I have new paint on my car. Wondering if a body shop can take the door skin off a donor door and put my door skin on so I won't have to repaint ?
probably easier to swap the window assemblies to manual on your existing door
https://ls1tech.com/forums/chevrolet...onversion.html
also if it's an alignment issue look here and try to fix it before you spend money on something you don't need. https://ls1tech.com/forums/appearanc...-write-up.html
My window is not moving up or down as it should. I'm thinking it might be related to window motor. The motor works fine I changed them 4 years ago. But I did not put lock tight on the screws. I didn't take the panel off to see what the problem is but if I change to manual their will be no issues with the fiberglass not holding everything in place. Manual means no repair problems. I changed the door to manual on a different Camaro but I was lucky to find the same color door at a junk yard. This car has does not have the stock color. Thanks for the link Daniel.
