Help popping out front fender dent.
Old 03-24-2017, 09:57 PM
Imperfect82's Avatar
Default Help popping out front fender dent.
Any suggestions on popping out a dent on the front fender? A cheap, yet effective method.
Old 03-25-2017, 11:06 AM
agenthol302's Avatar
really, no pics or dimensions......use a big *** magnet to get it
Old 03-25-2017, 03:04 PM
It's a 2012 TDI Jetta. The dent is directly above the driver side tire. I found a steel, primed fender online for $75. I'm not sure if I can pop out the stock fender. I guess taking it off is the only way to know? What would I use to pop it out?
Old 03-28-2017, 08:23 AM
hammer
Old 05-02-2017, 10:27 AM
Aaron23's Avatar
Remove the inner fender and see if you can push from the inside. Gentle pressure on a non-crimped dent can some be flexed back into position. Sometimes without even paint damage.
Careful with those Chinese car parts, they don't always fit the best.
Old 05-05-2017, 07:37 AM
bleepster's Avatar
seriously, if its just a dent with NO creases, use a toilet plunger. stick it to the fender in the middle of the dent and pull hard and fast - it should pop out.
Old 05-05-2017, 07:43 AM
fst100's Avatar
if its plastic, use hot/boiling water (seen it on a few youtube vids) followed by plunger
Old 05-05-2017, 07:50 AM
bigdaddy350's Avatar
Even if it's a steel fender, heat can help prevent the paint from cracking. Assuming it's not already cracked. If you hammer it from behind you will brake paint. Suction cup or pushing by heand from the back side is your best bet to get the majority of it out without hurthing the paint
Quick Reply: Help popping out front fender dent.
