fender installation
do you mean the nose of the car, b/c if you do then no, you dont technically have to remove that...there are 3 or 4 bolts that hold the front of the nose to the fender and a little tab bolt as well near the headlight, also there are two more bolts where the fender meets up near the door like where you would jack the car up on the frame, also there is one bolt inside the door if you open the door up and look right past the mirror youll see it and lastly the hardest one to get to is once your get all those bolts pry the fender back a little youll see a bracket holding the fender on you can remove the bracket or undo one bolt and just take it off from there, not to mention the 3 bolts that bolt the fender to the metal fender well
