My Clear is peeling on the hood, what grit sandpaper??????
What are you trying to accomplish with sanding? If the clear's peeling off the base, not much you can do except repaint it all. Which would mean you'd need to remove all of the existing clear (since it's delaminating) and paint over it from there.
the last camaro i fixed this problem on i wasnt able to save the base layer by just feathering the clear down so i had to strip it. In which case id start with 80grit, then then 2-3 coats of primer.
80 Grit?
I think that might be a bit extreme if all you want to do is feather back the clear. Which wont be there because it peeling away. Like Camaroholic said, you have to repaint it.
He said he stripped it with 80 grit, which is still excessive. Why would you strip an entire panel and put deep scratches in it, forcing more unnecessary work on yourself? He could have just saved himself time and money and wetsanded with 320 or 400 and reshot the base then clear, or in some situations just re-clear.
and if it makes u feel better, when i did it i didnt use 80 grit i used 40grit on a grinder. Not factoring dry times i had the hood prepped from base clear in maybe 30minutes and i know it was going to look how it needed.
Originally Posted by Pro-Mo
If you're going to prime it why take the risk of warping it using 40 and a grinder?
When u are expected to fix like 5-8 cars a day, u have to take some shortcuts here and there
