best cheapest chemicalmto clean gun with?
Have one gun and need to spray sealer then base coat then midecoat with pearl then clear coat. Whats the best way to clean the gun in between coats ?? I wont have time to take it all apart before it dries to much will I?
the HOK instructions are pretty specific to the flash time and next coat, I dont want to take to long and have to wait or sand.. Newbie, doing the engine bay for practice before I do the whole car...LOL
You can wait a max of about 30 minutes between the sealer and base if you want, and up to a day between coats of base, or between the base and clear without needing to sand for adhesion. But definately follow the HOK tech manuel, but it doesn't have to be as exact as they say. As stated above, lacquer thinner is the best/cheapest cleaner to use
laquer thinner. see if you can get some 3m pps cups aswell. the part number is 16000 and then get the correct fitting for you gun. it will save you the hassel of cleaning your gun.
PPS cups will not work with a siphon feed gun they are designed for gravity feed guns and aren't worth they money IMO unless you are spraying in a high production shop (where you wouldn't have to pay for them anyways). Just do as others have said and use lacquer thinner in between coats and the take the gun apart once you are finished and clean more thoroughly with lacquer thinner.
yeah most gravity guns around now are hvlp there are some people using standard pressure guns. You will always use more pressure in a siphon feed gun HVLP or not and will waste more material. You may be able to get a larger cup for the gravity gun you have or you could get an entry level gun from Harbor Freight or if you plan on spraying again in the future a Devilbiss starting line gun might be a better place to start.
Damn, should have asked before I bought. The one I got was $55 delivered so its not like it was top of the line but I have it so I'm not sure I should go buy another. Is there a big difference, is one easier to spray with than the other? how much for the devilbiss ? Arent they like 300 guns?
I have only used a siphon feed gun once and at first it was a pain to get it spraying right but once I did it wasn't too too bad just took some getting used to since I learned on gravity guns. If you plan on doing more painting in the future I would get a gravity gun, if you just plan on a one time thing or just every once in a while don't worry about it. The "starting line" guns are pretty cheap, look around online or go by your local paint supply shop I think I remember seeing a two gun kit (one w/ a primer tip and one w/ bc/cc tip) for about 100 bucks. I have been using their "finish line" guns which are like their middle of the road guns for about two years now and I love them.
Yeah I learned on SATA, I will probably get one when I come across a good deal on a solid used one. They are real nice but if you are just getting into painting or just doing it as a hobby then IMO you can find a gun that will shoot just as nice for a lot less money. My friend that swears by SATAs was surprised how well he did with my Devilbiss finishline guns. I think the big difference is durability but if you take good care of them and clean them well, some of the the cheaper guns work just fine.
You mean the Finish Line guns.
Edit: I feel stupid. I've been painting professionally for almost 10yrs. now and I have never heard of their Starting Line guns..... looked it up and now I have. MY BAD
On another note, all my guns are Devilbiss guns, I have (2) GTI's for base, a Plus for clear and a FInish Line with a1.8 fluid tip for high build primers.
I don't think they have been around for too long, maybe a couple years, a friend of mine that does this more for a hobby got a set of three guns for like $125. I know they are cheap but they really aren't all that bad. I am considering ordering a starting line gun for primer and they make a jamb gun as well that I'll probably pick up. That way I can have those two and my three finishline guns for base, pearls/metallics, and clear.
damn, no Iwata love in here....lol. One of the reps came down about 2 years ago, and was offering 20% off every Iwata product. Needless to say, everyone I know in baton rouge that paints uses iwata's.
