Corvette paint work -in realtime-
Old 07-31-2008, 12:57 PM
Sawzall and Welder Mod
Whistler's Avatar
Default Corvette paint work -in realtime-
The time has finally arrived... Let the painting begin!
Here's the original thread
https://ls1tech.com/forums/paint-body-work/944112-kandy-rockstar-pink-corvette-build-thread.html
This has probably been the most painstaking car I've done yet. This is due to the color, it's a candy so it cant be painted in pieces, but at the same time I didn't want to half *** anything. This meany taking everything apart, painting just the edges of all the parts (whatever is concealed with the car assembled and the doors closed)
The second problem is the base. It is an almost chrome-like silver that shows any wetsanding scratches through, so I didn't dare use a DA sander in fear of machine marks in the base. This meant sanding the whole thing by hand from 320 to 400 and then 600.
Here is the car as it sits now at 2:00 on Thursday
There are 14 layers of material that are going on this car .I am also doing the door handles, headlight lids, front plate and mirrors at the same time as to get the color as close as possible. I estimate I'll be spraying for about the next ten hours.
Old 07-31-2008, 02:20 PM
kamaro94's Avatar
Good Luck
Old 07-31-2008, 02:36 PM
Photochop's Avatar
Jeez, I'll be sure to check out the results tomorrow AM! Good luck man! I'm sure it'll look awesome.
Old 07-31-2008, 03:23 PM
Whistler's Avatar
Here's a quick shot of sealer on it. I don't want to seal it, as the texture of the primer will show in the metallic base, but the base is so fine that not using a sealer will show sand scratches in it. (I tried test panels three different ways)
Here's the first of about four coats of liquid metal base. This stuff s a bitch to lay out because it's over 90' out ad there s only one temp reducer available for it.
Old 07-31-2008, 04:52 PM
Whistler's Avatar
Here's the base almost finished. It's completely covered, i'm just playing with the metallic to get it even.
Old 07-31-2008, 04:54 PM
LS1TECH Sponsor
Joey@Tick's Avatar
Very cool thread. Best of luck!!
Old 07-31-2008, 04:57 PM
02gtp4now's Avatar
good luck man its going to look great
Old 07-31-2008, 05:01 PM
bricez28's Avatar
damn. nice.
Old 07-31-2008, 06:02 PM
V6Cam's Avatar
lookin good, cant wait to see the finished product
Old 07-31-2008, 06:21 PM
MjMaro's Avatar
A lot of work is going into this car, I'm anxiously waiting to see how it turns out, I wish you the best of luck!
Old 07-31-2008, 06:28 PM
dotcom396's Avatar
Very nice work. Definitely subscribing.
Old 07-31-2008, 06:48 PM
Camaro Ryder KV's Avatar
can't wait to see the finished product!
Old 07-31-2008, 06:58 PM
Corvettekid82's Avatar
Damn.. talk about pretty in pink. I'd even rock that when you're done with it.
Old 07-31-2008, 07:03 PM
Whistler's Avatar
Here's the last of the base... only 5 hours to spray that
And the first of the pink! I'll be the first to say it... it's ugly as hell! The first of it is thin, but as you add more coats it gets darker and more vibrant.
Old 07-31-2008, 07:20 PM
Simon Pheonixxx's Avatar
Man I know that is going to be the sickest pink car ever!!!! Can't wait to see how it comes out.
Old 07-31-2008, 07:36 PM
_JB_'s Avatar
Nice! Keep 'em coming!
Old 07-31-2008, 08:20 PM
Whistler's Avatar
Here you can see the difference that more kandy makes. The top has been done with an additional coat, and the sides have not
Now it's looking like something... one or two more coats and it'll be good!
Old 07-31-2008, 08:40 PM
aothepresident's Avatar
Looking good...
Old 07-31-2008, 08:52 PM
JimMueller's Avatar
I bet that brings back fond memories of past cars for you Lookin' good!!
Old 07-31-2008, 08:58 PM
UNDER PRESSURE MOD
The Alchemist's Avatar
Wow, amazing... but I actually like the look of the silver base better. Anyway you can keep the base as the final color and then put a top coat of clear?
Quick Reply: Corvette paint work -in realtime-
