Got some road paint on inside of fenders..
Old 08-08-2008, 11:33 AM
slikrider20's Avatar
Default Got some road paint on inside of fenders..
Well unfortunately it is everywhere, including on the paint on the side/underbody as well as in the plastic in the wheel wells. I did a little search and it looks like paint thinner will remove it. What tool should i use to apply this, and is there anything else i should know? I figured i would ask before i go screw something else up even more.
Old 08-08-2008, 01:03 PM
dimedsbc's Avatar
just under coat them
Old 08-08-2008, 01:18 PM
What is that?
Old 08-08-2008, 03:35 PM
LS1Tech Premium Sponsor
BMR Tech2's Avatar
Go to your local auto parts store and look in the paint section its called rubberized undercoating. Its in a spray can.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old 08-08-2008, 04:52 PM
I don't think you guys understand..or maybe i'm not. But it's all over my paint on my car, i need to get it off....
Old 08-08-2008, 05:53 PM
Ntimid8r7's Avatar
mineral spirits might work but I dont know if it will hurt the clear or not. dab a little on a sock or washcloth and rub it lightly until it starts to come off. try it in a spot that wont be very noticeable at first. you might even be able to use some sort of rubbing compound.
Old 08-08-2008, 06:03 PM
groundpoundinlt1's Avatar
lacquer thinner will take it off...put it on a microfiber towel or something similar with slight pressure; too much pressure will pull some of the clear off and then have a slight haze which will then need to be buffed...if its pretty fresh it will come off with ease
Old 08-08-2008, 07:29 PM
dimedsbc's Avatar
wd40!
Old 08-08-2008, 08:35 PM
I'll try the thinner with the towels, see how that works.
Old 08-08-2008, 08:38 PM
StevieZ's Avatar
not LACQUER thinner! It will melt the paint right quick. You mean paint thinner or varsol.
Old 08-08-2008, 09:38 PM
NO i mean lacquer thinner...i work with it everyday and use it in this same instance daily!! Paint thinner is stronger than lacquer and will eat clear coat for breakfast!!!
Old 08-09-2008, 12:30 AM
redramair98's Avatar
whipe it off with laquer thiiner it might haze up a bit but it will buff and shine right up, try a small area thats not so noticeable first
Quick Reply: Got some road paint on inside of fenders..
