MS4 Cam, SLP oil pump, Lunati valve springs, Roll Master double roller..
Category: Accessories
Price: $2147483647
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette
Location (State): CA
Item Condition: Brand New
Engine: LS1/LS6
LS Engine?: Fits LS Engine
Email Ryancdirks@gmail.com
Paypal is ryu209@tmail.com
Contact me at 209 277 3245
I have a used comp cam (low miles lobes all look to be in excellent condition) that I bought from another member on here whom works for speed inc its the same spec as MS4 and was sold to me as a MS4 but here is the cam card 300 SHIPPED
SERIAL # R 8422-09 SPEC CARD # 16519309 SPEC CARD INQUIRY BY SERIAL #
PART # 54-000-11 CAMSHAFT, LS1 CHEVY LS1/GEN III '97-UP
CORE C54-11II CAMSHAFT BLANK, LS1 1997 UP 5.7 CORVETTE Special Grind
GRIND # LS1 2130R /3731R HR111 +1
DURATION @ .050 INTAKE 239 ROCKER ARM RATIO
VALVE ADJ INTAKE .000 DURATION @ .050 EXHAUST 242 INTAKE 1.70
VALVE ADJ EXHAUST .000 LOBE LIFT INTAKE .3830 EXHAUST 1.70
VALVE LIFT INTAKE .651 LOBE LIFT EXHAUST .3590
VALVE LIFT EXHAUST .610 LOBE SEPARATION 111.0
DURATION .006 INTAKE C/L 110.0
TAPPET LIFT INTAKE 289 CAM ADVANCE 1
TAPPET LIFT EXHAUST 291 HYDRAULIC Y
VALVE TIMING .050 OVERHEAD CAM N
VALVE OPEN INTAKE 9 JOURNAL DIAMETER STD 2.165
VALVE OPEN EXHAUST 53 RECOMMEND VALVE SPRINGS
VALVE CLOSED INTAKE 49 DEPARTMENT P
VALVE CLOSED EXHAUST 9 SPC INSTR FOR CUSTOMER
NEW Rollmaster double roller timing chain 100 SHIPPED
SLP ported oil pump I bought it off a guy who had it on his motor that was being built.. I was told it was never used just mounted 150 SHIPPED
New .660 lift Lunati dual spring 200 SHIPPED
Email or PM with Q's..
THANKS!
