Ls2 short block, nx efi kit, l92 heads, 243 heads lots of stuff...
Category: Accessories
Price: $1500
Part Fits: 2010+ Camaro, 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V
Location (State): MO
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6
LS Engine?: Fits LS Engine
LS2 short block 58x bearing are perfect great condition $1500
No heads, oil pan, front cover, etc,
L92 heads with valves springs and rocker arms cleaned and surfaced .004
$650
1 SET SOLD 1 LEFT
NX EFI nitrous kit complete wet kit NEW! NX #20118-10 $350 ($736 from summit)
YellaTerra shaft rockers LS1 #6638 NEW in box $350 reduced
Bmr Torque arm reloction brakcet turbo 350 new $150 reduced
Stock ported LS1 throttle body $ 85 reduced
LS3 like new intake Manifold bare only 10 miles $200
Yella Terra 6645 Shaft Rockers for direct replacement on Hydraulic cams and
works on most oem and aftermarket heads factory clearanced for .650 springs. New! $400
LS2 Timing cover with sensor $50 with new gasket and seals $100
F body t-56 factory crossmember $35
T56 ls1 fbody throwout bearing assembly Like new (possibly is new) $100
Heat sync Truck coils brackets and harness nice! $150
Ls3 Coils brackets and harness new $175
Ls1 valve covers $50 with new gaskets
LS3 L92 valve covers like new with new gaskets
Auburn posi unit for 10 bolt 7.5" with 3.08 gears $225 reduced
NOS 78 mm Nitrous plate only $90 reduced
243 heads low miles cleaned and checked at machine shop with factory
valves and springs. $ 400 1 SET left 2 sold
All prices plus shipping and paypal fees if applicable
Best to call or text 502-612-6348
Here is some pics but not of everything can get more pics if needed.
I will post some pics this evening. I would guess gen 4 but I will have to look I bought a bunch of Ls engines and this was in the lit and I havent really do ne any research on it yet. But Itook pics of the numbers and reluctor so i could see if I could figure it out from the pics.
