Lonnies Performance Fbody '99-02 LS1 Twin High Output Fuel Pump Kit - $400
Category: Engine - Intake/Fuel
Price: $400
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird
Location (State): TN
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6, LT1/LT4
LS Engine?: Fits LS Engine
everything you see there
Pumps are pre-installed into the fuel bucket
Just drop the thing into your fuel tank....
plug in your stock fuel level wiring connector, and run the wiring harness up to the front of the car and connect to appropriate spots to power the pumps.
both pumps can be enabled to turn on all the time, or you can use only one,and turn on the second one as needed.
you need to supply your own feed and return lines and fittings
works great... I just cant use this with my new setup.
