CP Pistons, Splayed Block, Moroso Oil Pan & MORE!
Category: Engine - Complete Motors
Price: $1
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird
Location (State): PA
Item Condition: Brand New
Engine: LT1/LT4
LS Engine?: Non-LS Part
Moroso 5.5qt LTx oil pan. Had an engine come apart in it and has had most of the initial weld back done up. Needs a little finishing on the interior and mounting surfaces to be useful again. This pan sells for 260ish new so you can get some serious savings picking this one up and doing a little work to it. $50.00
Factory OBD2 PCM from 1996 Trans Am M6 w/3.42 gears. It has a factory tune up on it still. $OFFER
Factory clutch hydraulics without slave cylinder, good condition, worked great until I swapped to a tilton setup. $OFFER
CP forged nitrous pistons, high quality pieces. These pistons have a unique compression height, not seen normally in a 390 inch buildup because most people go for the 396 inch mark on the LTx. I was going for a 391 inch build with an oddball rod and crank length to keep the piston skirts from coming out of the bore bottoms too much. This was going in my high horsepower LTx buildup I've been working on for awhile. Its time to move them along and move on to my next project though. They've been taken out of the box and inspected but other then that nothing has been done to them. They come with pins locks and hardware - no rings. $400.00
LTx block converted over to howards billet 4 bolt splayed mains, stroker clearanced (roughed in, you should always check during final asssembly), bored 4.030 but will need a final hone during assembly. This block is bad-*** and is ready for a quad digit build up with the right combination. I have a little over 350 in the main cap work alone. I'm looking to get $500 for the block. I would do a bulk deal if someone wanted to take the pistons with it.
Weld Drag Lites with skinnies for F-Body FRONTS ONLY. These have been for sale on and off for awhile so I'm lowering them down to $300.00 including the tires. They come with the decorative center caps, lugs, and spacers needed however you will need wheel studs to run these!
