Huron Speed A/C Retaining Turbo Kit + Turbo/WG/BOV/Oil-Lines
Category: Accessories
Price: $3495
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird
Location (State): MI
Item Condition: Brand New
Engine: LS1/LS6
LS Engine?: Fits LS Engine
-ONE complete package deal In-Stock and shipping daily, no wait time! Don't Miss out!
This package special is in stock, and is available to ONLY the first person to purchase for a $800 savings!!!!
***Kit has many of the same features as the already successful kit Truck Manifold kit, however obviously retaining A/C with the use of a C6 manifold and a truck manifold combination fitting through a Turbo K-member. Kit will require the use of a Turbo K-member (was built around a PA Racing Super Turbo K-member) This can be purchased with your kit for a great price, or separately.
Includes:
-Your choice of the following PROPERLY SIZED for LS1 Turbochargers with the LARGER 75mm+ turbine wheels:
*Turbonetics 7875 .96 a/r Ball Bearing Turbocharger
*Turbonetics 7875 1.15 a/r Ball Bearing Turbocharger
*Precision 7675 .96 a/r Journal Bearing Turbocharger
*Comp 7679 .96 a/r Journal Bearing Turbocharger
-2-piece hotside in 2.5” piping w/ T4 flange and 44mm Wastegate Flange
-2.5” V-band clamp for easy connection of 2 hotside pipes.
-3” 1-piece Downpipe
-3" Cold side piping from turbo to FMIC to Throttle Body
-MAF Delete pipe
-50mm Blow-Off Valve Flange on Cold side piping
-4" core front mount Intercooler
-All exact, specific couplers
-Extra exact couplers to run or not run the MAF Delete
-All exact, specific T-Bolt clamps
-F-body front mount intercoolers brackets
-F-body alternator & tensioner relocation brackets
-Hardware to mount Turbo, intercooler brackets, intercooler, alternator & tensioner relocation to vehicle
-XSPower 44mm Wastegate (Black, Silver, Red or Blue)
-XSPower 50mm BOV (Black, Silver, Red or Blue)
-Oil Feed and Drain Line kit w/ fittings
$3495 + FREE SHIPPING
-We can add in a PA Racing Super Turbo K-member to this package for you for $550
All piping made from 321 stainless steel, fully polished.
Advantage of using factory GM manifolds, no fear of aftermarket headers or manifolds cracking due to the turbo weight!
Advantage of having the Huron Speed customer service!
Requires Oil Lines, Pusher Fans, Misc Hardware, passenger side Truck Manifold to use on drivers side, and a passenger side C6 Manifold to run on the passenger side to complete
Kit requires a Turbo K-member (built around the PA Racing Super Turbo K-member) and lowering or removal of front sway bar
Huron Speed
Kit shown as you will receive it (You can select the color of your Wastegate and BOV)
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
